Mulching with the 60" MMM
/ Mulching with the 60" MMM #1
dtmarion
Cumberland, Rhode Island
Jan 2, 2002 B7500
Mulching with the 60\" MMM
Is there some type of mulching kit that can be attached to the BX2200 or B7500 with the 60" MMM or do I have to buy a catcher? Just wondering...
<P ID="edit"><FONT SIZE=-1>Edited by dtmarion on 11/06/01 06:22 PM (server time).</FONT></P>
/ Mulching with the 60" MMM #2
Re: Mulching with the 60\" MMM
There is a mulch kit for the BX 60 inch MMM. I do not have a stock number but I have seen one installed--it is fairly pricey and probably not needed. The 7500---do not know, maybe someone else does. J
Re: Mulching with the 60" MMM
Why do you suggest that it's not needed. I'm curious because currently I mulch my lawn and I'm not to keen on idea of spending $1500 or so on a grass catcher with my new tractor. Do the three blades work that well?
/ Mulching with the 60" MMM #4
The 3 blades on my 60" mmm do a great job on the leaves in my yard, in fact, the last 2 times I mowed the yard it was more to clean up the leave than to cut the grass. The blades create a leaf mulch, i.e., there's not much left that's identifiable as a leaf.
Typically, I mow clockwise which means I am recutting the grass and leaves from the previous pass. For those areas that I can not mow clockwise, I make sure the discharge chute blows towards a hedgerow.
/ Mulching with the 60" MMM #5
If you keep your blades in good shape mowing over leaves with just the 60' MMM chops 'em enough where you don't even need to mulch. I'm always amazed at the quality of the cut provided, and even the occasional 1/2" thick stick gets pulverized with no problem.
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
Titan Attachments Forks (A64126)
Titan Attachments...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
