Muffler replacement "glitch"
/ Muffler replacement "glitch" #1
Trkrd
Arkansas
YM240D
Been putting bandaids on my muffler for some time now and seeing I needed to order a new tie rod end from Hoye anyway, thought I'd give the Yannie a treat and get him a new muffler. As you've probably guessed by now, even after 4 days of soaking with PB Blaster, ALL the mounting studs broke ! Going to town for helicoils and studs but not sure of the size. I think M8 ? but not sure. Any idea??
/ Muffler replacement "glitch" #2
Yes, those studs can be a pain. They are M8x1.25 thread
/ Muffler replacement "glitch" #3
should have used kroil oil, put it on mine for a week and backed out the bolts with a 3/8 ratchet, surprised me they came out so easy .
/ Muffler replacement "glitch" #4
I'm a firm believer and user of Kroil too. In a pinch, if you are out of Kroil, a 50/50 mix of ATF and acetone works just about as well. Must be stored in a metal or glass container though.
I was able to get it done yesterday. After cleaning away the rust from around what was left of the broken studs, I was able to get the vise grips on the 2 innermost studs and work them out successfully. Had to drill out the other 2. One went fine and of course the last one was a mess, so only needed to use 1 helicoil. Easy to do on the bench. I was really surprised how easily the manifold came off. Thought I'd be breaking studs there too, but they came right off with no hassle whatsoever.
/ Muffler replacement "glitch" #6
Next time, with hot engine, apply candle wax. Heat will suck it right in, and out it comes.
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
