Muffler replacement "glitch"
/ Muffler replacement "glitch" #1
Trkrd
Arkansas
YM240D
Been putting bandaids on my muffler for some time now and seeing I needed to order a new tie rod end from Hoye anyway, thought I'd give the Yannie a treat and get him a new muffler. As you've probably guessed by now, even after 4 days of soaking with PB Blaster, ALL the mounting studs broke ! Going to town for helicoils and studs but not sure of the size. I think M8 ? but not sure. Any idea??
/ Muffler replacement "glitch" #2
Yes, those studs can be a pain. They are M8x1.25 thread
/ Muffler replacement "glitch" #3
should have used kroil oil, put it on mine for a week and backed out the bolts with a 3/8 ratchet, surprised me they came out so easy .
/ Muffler replacement "glitch" #4
I'm a firm believer and user of Kroil too. In a pinch, if you are out of Kroil, a 50/50 mix of ATF and acetone works just about as well. Must be stored in a metal or glass container though.
I was able to get it done yesterday. After cleaning away the rust from around what was left of the broken studs, I was able to get the vise grips on the 2 innermost studs and work them out successfully. Had to drill out the other 2. One went fine and of course the last one was a mess, so only needed to use 1 helicoil. Easy to do on the bench. I was really surprised how easily the manifold came off. Thought I'd be breaking studs there too, but they came right off with no hassle whatsoever.
/ Muffler replacement "glitch" #6
Next time, with hot engine, apply candle wax. Heat will suck it right in, and out it comes.
2005 Volvo VHD Roll Off Truck, VIN # 4V5KC9GF75N395481 (A65563)
2005 Volvo VHD...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Kiefer Built Livestock Trailer (A66285)
Kiefer Built...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Hedge Posts (A65640)
John Deere 1025R (A62177)
John Deere 1025R...
