Much faster
/ Much faster #1
rustyshakelford
Texas
Deere 5100E/H260/MX15
Tractor was finally ready to come home after being at the shop since the 1st. Normally I will hook up my trailer, drive to the dealer, load and chain everything down and drive home. The dealer is only about 16 miles away. I was getting it and the batwing that had a wing cylinder seal replaced. I ended up having a buddy carry me to the dealer and drove it home. It took me 40 mins to come home vs about an hour and a half when all things are considered with hooking and unhooking the Trailer and the load/unload time. I don稚 think I知 going to be hauling much anymore after this.
Itç—´ a option for those that live close and don稚 want to mess with a trailer especially if youæ±*e in a rural area
Brett
/ Much faster #4
The Kubota dealer is only 3 miles from my house. Would be an easy drive home on all back roads except about 0.3 miles.
Mahindra/New Holland dealer is a little farther...about 18 miles but he's located along a semi-limited access highway.
/ Much faster #5
Getting to the Kubota dealer would mean driving about 18 miles on I-90. I don't like I-90 - even when driving in my pickup. Then I would have to navigate thru downtown Spokane. I'm sure the operation would offend somebodies delicate sensibilities.
/ Much faster #6
It must suck living with so many snowflakes around!
/ Much faster #8
That speedo readout must be showing KPH as that deere surely doesn't do 25.3 MPH. :)
/ Much faster
Isn't a paved road hard on tractor tires? Just wondering?
Not as bad as you would think. If youæ±*e ever on agtalk thereç—´ guys that will road a tractor up to 250 miles to help bring an impliment home to Save on shipping especially if itç—´ ovesized. Same thing with moving equipment around or something bought at auction.
That痴 one of the perks to the 24/12 trans. It値l run pretty good out on the road. MPH all day!
Brett
/ Much faster #10
Some brands of tractor tires wear much better on paved roads than others. My JD 4255 (11,600 hrs) with radial Continental rear tires has been driven on paved roads over a 1000 miles in the last 20 yrs performing custom baling with little noticeable wear. A lot of times the cleats will begin to wear uneven & form cups but not on these tires. I'll try to remember to post a photo of my rear tires later today.
/ Much faster #11
I pulled it in closer. It's MPH.....:confused3:
/ Much faster #12
I'm really starting to love my power reversal. Mine is only a 12/12 but top speed is just under 30MPH. To hairy for me and I don't like driving at full throttle unless in the field.
/ Much faster #13
Dang. It takes me 45 mins to go 10 miles on any of my tractors.
/ Much faster #14
If I could run 25 mph I'd probably do the same time. My tractors run closer to 10 mph.
/ Much faster #15
"guys that will road a tractor up to 250 miles to help bring an impliment home to Save on shipping especially if it痴 ovesized. Same thing with moving equipment around or something bought at auction."
wow, that would be a heck of a ride.
/ Much faster #16
Seems all the skid steer machines with cleat tires are always worn out in the middle.
/ Much faster #18
I road my L4060 more than haul it. Most of my side work is under a 30-40 minute tractor drive away. I can barely load out on the trailer on the short side of that, much less haul it too. Most is on dirt roads though, I don't road over pavement unless it's under a mile or so. The L4060 will only hit 15mph downhill too, single digits on any kind of hill.
2007 PETERBILT 379 6X4 TRI/AXLE DAY CAB TRUCK TRACTOR (A59914)
2007 PETERBILT 379...
2015 Chevrolet Silverado 2500 (A62613)
2015 Chevrolet...
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2007 International 8600 Truck (A62613)
2007 International...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A65563)
2004 MCI D4500...
