mt265b wont move
/ mt265b wont move #1
jlicitra523
2005 mt265b challenger
so i have a mt265b challenger and once and a while i can get it to move but then other days it wont at all. like it will manly in turtle mode and in first. to me it seem like the clutch isnt grabing but it had a new clutch put on and the flywheel resurfaced and the guy drove it for like 30mins and it stop working again. so when i went to but it i just adjusted the linkage and got it to move but now im having the same issuse again run for a little while then it wont want to move. if any one has any idea that would be great
/ mt265b wont move #3
Welcome to TBN.
When you adjusted the clutch, did you have any free play on the clutch pedal? 1” at least?
/ mt265b wont move
Welcome to TBN.
i have like a 1/2 of free play but that adjuster is maxed to the point of if i adusted it anymore the threads will come out. that what im so confused about its a new clutch i thought that adjuster would be all the way in. i can take a video tomorrow and show you what i mean.
/ mt265b wont move #5
I’m thinking the mechanic left the pressure plate finger locks in place. This would keep the pressure plate disengaged and would explain why your clutch adjustment is so extreme. It wouldn’t be the first time it has happened.
/ mt265b wont move
ok so over a whole year later I'm back working on this thing fixed the first problem solenoid had bad wires got that all fix but now it moves every time it's like there is just no ass and like i put it in rabbit mode and it takes forever to start moving but once it gets going its good. I'm going to do a full service to it. 2 questions is the a separate screen from the filter. and can I use tractor supply fluid i didn't find one that actually said mt265b
/ mt265b wont move #7
I'm not familiar with all the Iseki built tractors, but if you hope for any accurate answers to your questions it might help if you clarified which transmission you have. Is this a dry clutch mechanical shuttle or a power shuttle? Power shuttle systems have multiple possibilities for problems.
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
(2) 16.9-30 TRACTOR TIRES (A64281)
(2) 16.9-30...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
