MT225E Random Cotter Pin
/ MT225E Random Cotter Pin #1
Waffles
SLO, CA
MT225HE
I was checking out my under carriage and saw a cotter pin that appears to do nothing. Does anyone else have this?
/ MT225E Random Cotter Pin #2
I'm wondering if that is a drain hole for the clutch area? If oil starts to drip out, a seal is leaking. The cotter pin keeps it from plugging as it moves around.
/ MT225E Random Cotter Pin #3
Agree. I've seen this technique used on many machines to keep a weep hole clear. Works good on all but the dirtiest conditions--Like the bottom of a tractor. :cool:
You can give it a giggle every once in a while to make sure it's loose and free to move.
/ MT225E Random Cotter Pin #4
Yes, that is exactly what it is for! To break surface tension on any moisture or fluid inside the case and to allow it to drip out.
I had noticed the stray "cotter pin" a couple days after I got the tractor..... called the dealer and sent him a picture of it, leaving him a message asking if I could / should pull it out.. ...
He called me back within 2 minutes Immediately saying "DON'T pull it out !!" He then explained its use.
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
3268 (A63117)
3268 (A63117)
