MT1601D transmission issues again!
/ MT1601D transmission issues again! #1
GAdawgs
Dallas, GA
MTD1601D
I have tried to attach a picture of my gear housing after a 5 minute drive. It is completely foam, I may be wrong but I don't think it is supposed to do that. I have no speed or power in 2nd and 3rd, and it won't even move on an incline. 1st has some speed, but very little power. I had to crack the tractor in the fall to break the clutch from the flywheel. Do you think I screwed something up putting it back together or could it be as simple as bad fluid?
Any help is appreciated. Thanks.
/ MT1601D transmission issues again! #2
I am quite sure about 2 issue in your case. First for the tractor not moving it more a clutch issue. You may try to adjust the pedal link. For the foam in the transmission it more a leak on the suction line. could be the o ring a the oil pump.
/ MT1601D transmission issues again! #3
You are a geared tractor, the foam is in all probability water mixed in with the oil. Generally water can enter from a split rubber boot around the shifter. Replace if so , drain all fluid and replace with appropriate grade tractor hydraukic fluid.
I agree with clutch issue, again water can cause grief with the clutch sticking.
There is a screen to filter the fluid and if that is clogged it could also explain foam.
Milky frothy fluid is generally water mixed in.
I own a MT180D which is basically the same as your grey 1601. (4 digits=grey)
/ MT1601D transmission issues again! #4
I agree with above and have one more thing to add. I think you have too much oil in there. There is a fill level plug on the side. When you drain and refill, take that fill level plug out. When oil starts running out while filling, you are done.
/ MT1601D transmission issues again! #5
This may not help your specific current issues ( but I would look at adjusting your clutch pedal as described in the manual) and it may help in the future with other issues. http://home.comcast.net/~tdepooter/Mitsubishi MT160-180 Instruction Book Optimized.pdf is a free OEM operators manual for MT160/MT180 models. If you don't have one, save it to favorites AND print a copy. I&T's Mitsubishi MT160/MT180 or their MT160-Mt300 repair manual would be a must have. Almost always available on Ebay for under $20. I&T mitsubishi manual in Manuals & Books | eBay
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
(5) Drive Motors (A64119)
(5) Drive Motors...
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
CONEX BOX (A65643)
CONEX BOX (A65643)
