MT125 customization
/ MT125 customization
I'm not lifting anything super heavy so I got mine at TSC, I think about $13 or 14 bucks. I was just at Harbor Freight and saw some bolt on hooks for $10 ea. I'm going to get 2 more of those. They also have the 1/2" shackles on sale for $5, the 3/4 shackles for $10. Can't beat those prices. I put the shackles on my mower and box blade so lifting them is a breeze.
I just remembered to take pics of the stabilizer "feet" that I put on the BH. The holes were there on the BH stabilizers, just had to drill the angle iron. Took all of about 30 min to do. Made a BIG improvement.
Oh, another maintanance tip.... If you look at the grease zerk on the stabilizer in the previous pics, it has a rubber "cap" on it. Every zerk on the tractor now has them. Keeps them nice and clean, ready for greasing. Only lost one, I think I brushed against one and knocked it off. Bought a pack of 50 for around $12 bucks on Ebay. They come in all colors, which helps to find all the zerks also.
/ MT125 customization #25
That is a great idea. The angle iron must act like cleats. I need to learn how to weld but nice that you didn't have to drill the stabilizer feet.
/ MT125 customization #26
Another great idea. Do you use a regular grease gun, air powered,cordless??
You don't have to weld for these. You can get a 3-4' stick of angle iron at pretty much any hardware store. Just cut it to length, drill matching holes to the stabilizer feet and bolt on.
The first time I lubed everything, I used my cheapie manual one. Went and got an air powered one at O'Reilly's auto parts ( Lincoln brand). Never looked back! Made it much, much easier. I use a coiled air hose, so it reaches all the way around the tractor w/o any problem.
/ MT125 customization #29
I have all Dewalt cordless tools. I may try their cordless grease gun. Plan B is the air powered gun. Hopefully it's better than Dewalt's cordless caulking gun which is very messy to use.
/ MT125 customization #30
Where did you get the wheel spacers?
I致e been making a few 奏hings for my 125 and will be adding, such as this storage dolly for the MMM.
/ MT125 customization #31
Since the MT125 didn’t have a quick attach, I had to cut the brackets A975BE7F-D280-4ABF-B5F4-A5B938F96E2A.jpeg990E3762-4A36-4A32-827B-FF1EFC979D07.jpegB99EC3D3-59A0-43E9-A331-965BB4F1ECB6.jpegand modify a Titan forklift attachment to work. Really get a lot of use out of this.
Nice job on both projects. Did you make a quick attach or is it still a pin on?
/ MT125 customization #33
It’s still a pin-on. I thought about building a QA plate but in the end decided I couldn’t think of another loader implement I really needed so just duplicated the attach structure on the back of the bucket. Also with this Titan forklift setup, you can remove the forks and insert other things into those brackets if i wanted to mount something.
/ MT125 customization #34
Had some vacation time so I built a quick attach for the FEL to fit the original bucket and the new forks. Not as smooth as a SSQA setup but it works pretty well. No comments on the welding.. some of these were work in process shots that got cleaned up later.
BD759B99-0D18-4942-8F56-61D5BD7A5D49.jpeg2D085E2B-6D27-4626-8EA3-339E7FD412F8.jpegF17914A9-25A6-4D2C-AA90-C1DF87BAD77A.jpeg
/ MT125 customization #37
Yes. Top two pins stay in the bucket and you drive up, hook in, tilt back, then climb down and wiggle the bottom two pins in. Saw this design used on the small Kubotas and copied.
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2019 Toyota Camry Hybrid Sedan (A64557)
2019 Toyota Camry...
