MT 573 Issues
/ MT 573 Issues #41
Well fellas. Looks like my good streak just ran out. Was plowing and got the beep. Caution and stop displayed. Error code f02 s636
/ MT 573 Issues #42
That appears to be a Crank Signal Early fault, lost fault, missing fault, or over speed fault. I've attached some screen shots from the service manual. Hopefully its just a loose wire or sensor, or bad sensor.
/ MT 573 Issues #43
I see a few post about a recall on the harness on the smaller tractors. Wonder if mine has one. Really sucks. Was in the middle of plowing to beat the rain.
/ MT 573 Issues #44
Crank sensor failing is pretty common. Part # 40511370. Easy fix and falls under 5 year emissions warranty.
/ MT 573 Issues #45
I also want more protection for brush and to add some holes for chains. I hate chaining over the axle to haul.
I had expanded metal added to my bush guard and a clevis that I can put a shackle on to run chain through for transport. Guess you could weld a grab hook there since you take your bucket off.
/ MT 573 Issues #46
A while back I took some 1/2" plate (I think its half inch, don't really remember) scrap I had, cut it so it would hang down a bit from the frame, drilled some holes in the plate to match the ones already on the frame, and then welded some D-rings to the bottom portion. I did this on both sides. This is where I typically keep a chain, and where I tie the tractor down to a trailer.
/ MT 573 Issues
Both good ideas!
/ MT 573 Issues #49
I did similar, I made these out of some scrap 3/8" steel I had. I have ratcheting straps with safety hooks that snap right on quick and easy.
Easy Lawn Hydro Seeder (A65579)
Easy Lawn Hydro...
2023 New Holland Boomer 45 Tractor (A65579)
2023 New Holland...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2020 Deere 333G (A64126)
2020 Deere 333G...
90in. Work Bench (A65640)
90in. Work Bench...
