MT 573 Issues
/ MT 573 Issues #41
Well fellas. Looks like my good streak just ran out. Was plowing and got the beep. Caution and stop displayed. Error code f02 s636
/ MT 573 Issues #42
That appears to be a Crank Signal Early fault, lost fault, missing fault, or over speed fault. I've attached some screen shots from the service manual. Hopefully its just a loose wire or sensor, or bad sensor.
/ MT 573 Issues #43
I see a few post about a recall on the harness on the smaller tractors. Wonder if mine has one. Really sucks. Was in the middle of plowing to beat the rain.
/ MT 573 Issues #44
Crank sensor failing is pretty common. Part # 40511370. Easy fix and falls under 5 year emissions warranty.
/ MT 573 Issues #45
I also want more protection for brush and to add some holes for chains. I hate chaining over the axle to haul.
I had expanded metal added to my bush guard and a clevis that I can put a shackle on to run chain through for transport. Guess you could weld a grab hook there since you take your bucket off.
/ MT 573 Issues #46
A while back I took some 1/2" plate (I think its half inch, don't really remember) scrap I had, cut it so it would hang down a bit from the frame, drilled some holes in the plate to match the ones already on the frame, and then welded some D-rings to the bottom portion. I did this on both sides. This is where I typically keep a chain, and where I tie the tractor down to a trailer.
/ MT 573 Issues
Both good ideas!
/ MT 573 Issues #49
I did similar, I made these out of some scrap 3/8" steel I had. I have ratcheting straps with safety hooks that snap right on quick and easy.
Longhorn Skull (A65583)
Longhorn Skull...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
(4) Kinze Gauge Wheels (A65640)
(4) Kinze Gauge...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
Mini Universal Forks (A65640)
Mini Universal...
