mt-125 overheat
/ mt-125 overheat #1
ls kelly
HOMOSASSA FL
mt-125
cautionary tale: was mowing around my pines and oaks mulching up last years leaf drops for the last time till fall. noticed coolant guage in red!!! shut her down , got the manual troubleshoot and of course loose or broken belt,coolant level. One thing not mentioned and was the culprit was the removable radiator screen/filter. Moral of the story is it will clog during nasty mowing conditions.
I wonder if this unit has a shut down or limp mode like yamaha outboards do when they overheat?
/ mt-125 overheat #2
The big front filter was covered? You might want to also check the little air filter cylinder.
/ mt-125 overheat #3
I think he was talking about the slide out radiator screen. But it would be a good idea to take a look at the air filters.
/ mt-125 overheat
i was talking about slide out radiator screen. i wish i would have been wearing a respirator also. next time.
/ mt-125 overheat #5
I always take a gas powered leaf blower with me just for this reason. I blow the radiator out every hour or so ---- depends on how much trash I scare up while working.
/ mt-125 overheat #6
It happens on most of the subcompact because they are so low. My John Deere 1025R and my Massey Ferguson GC1705 both would over heat if the screens were not cleaned regularly. My GC1705 was the worse of the 2. I have only mowed twice with my LS MT125, so I will watch it.
/ mt-125 overheat
I'm loving the tractor and the 3 blade belly mower mulches leaves nicely. Did an oil change and air cleaner change after that mow. I was at 43 hours anyway. Tractor is running great.
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
2006 Freightliner Box Truck (A61573)
2006 Freightliner...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
INSPECTION (A65579)
INSPECTION (A65579)
SHORTWOOD LOG TRAILER (A64276)
SHORTWOOD LOG...
