MT 125 Bolt Pattern
/ MT 125 Bolt Pattern #1
Twalter91
LS MT 125
Hey everyone im looking at making some 2" wheel spacers for my Mt125. The ones I see online are way to expensive so going to make my own on a cnc machine. Is it 5x4.5? Hard to find any info online. Thanks
/ MT 125 Bolt Pattern #2
This will be the bolt circle for a 5 hole wheel.
/ MT 125 Bolt Pattern #4
Are you going to make your spacers so that they are hubcentric so not all the load is carried by the lugs.
Yes, they are 5x4.5
Thats what i thought. I researched some old threads on here and i thought i seen that you said you bought some 5x4.5 and they didn't work? Just wondering.
Yes im going to. Havent measured the hub yet but I plan on boring middle hole so its a perfect fit to it.
/ MT 125 Bolt Pattern #8
Yes, I did buy the 5 x 4.5" spacers, but the hub centric centers were too small by about 3/16". I just honed out the hub centric to fit. Had them on the tractor for about 150 hours without issue.
/ MT 125 Bolt Pattern #9
Has anyone measured the center bore? My tractor is not home right now and I’d like to order some spacers. If I can’t find exact I’d like the bore to be smaller then I’ll make them the correct size on the lathe.
/ MT 125 Bolt Pattern #10
When I was looking for mine, I couldn't find any with the exact fit. I am sure someone out there would custom make them, but it would be costly. Sounds like you can machine them yourself, so just get the closest you can.
I got the set of 2.5" (all 4) for $150 shipped. Just go on Ebay and search for 5x4.5 wheel spacers..... should get about 1000 hits.
That's where I got mine, specifically for a Jeep XJ Cherokee. I spent about 2 hours machining a small "Lip" on the hub centric to fit the tractor.
/ MT 125 Bolt Pattern #11
Thank you very much. I found two 2 inch on Amazon for $58.
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A59914)
2007 VOLVO VHD...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
