MS390 fuel flow issue...?
/ MS390 fuel flow issue...? #1
/pine
Super Star Member
I'm just starting a net search but thought I would post the problem here...
The saw starts and runs but it runs out of fuel if not held inverted or vertical...should not be a big issue...just never had the saw apart before...any insights from 390 owners?
/ MS390 fuel flow issue...? #2
If it sounds like its loading up on the rich side, I would suspect the float is sticking, or dirt on the needle valve.
If it has has ethanol mixed and sat, you may have to rebuild the carb or replace the carb.
I have mixed pine-sol 3 parts water, 1 part PS, and soaked bike carbs over night with good results, removing all tarnish interior and exterior, and the turpentine doesn't damage the seats, there are your tube vids on before and afters.
Use caution you don't bent the float tabs.
I have never been inside the husky carb, but suspect it's very much like a dirt bike carb, on a smaller scale.
/ MS390 fuel flow issue...? #3
No float inside the carb though.
Thanks for the replies...I also thought it seemed like something sticking so I thumped the saw on the ground a couple of times and though I have not done any cutting with it since...it seems to be running fine again (any position)...who knows...I have always used 100% gas in the saw...maybe I'll add a little Seafoam...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
3145 (A63117)
3145 (A63117)
2022 John Deere 5100E (A64126)
2022 John Deere...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2008 Bobcat T300 (A64126)
2008 Bobcat T300...
