mr heater recommendations
/ mr heater recommendations #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
i am looking at mr heater propane heaters for my truck shop. any recommendations? i have 2 @ 100 lb tanks plus several 20 lb tanks. shop is 24 x 36 with 15 tall ceiling. looking at the forced air line or the convection. any thoughts would be greatly appreciated. thanks, johnny
/ mr heater recommendations #2
With a 15' ceiling, you may also want some blowers up in the overhead to push all that warm air back down where you can feel it:)
/ mr heater recommendations #4
You don't say how insulated the building is? I have installed several Empire direct vent heaters, and some Ecotherm units. They all use a twin tube vent, with the inner tube being the flue, the outer tube bringing in the combustion air. They seem to work well, and are pretty safe, in that you aren't combusting shop air. The Empire units had fans built in. For your building, you might want to look at a hanging space heater- they are also available with the outside air feed, I think. I presently heat a 32' x 24' x 8.5' shop with a 30,000 btu unit, no fan, but the building is pretty well insulated, and I aim for 60 degrees.
It takes a long time to bring up the heat (outside temps in the 20's, for example) so I try to keep it at 45 or so all the time. Insulation is the key... even some rigid foam boards under the slab perimeter.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A65643)
2008 MOTIV...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
