Mowing Mowing lawn with a BX - Belly mower or Tow behind?
   / Mowing lawn with a BX - Belly mower or Tow behind? #11
This may be a dumb question - but why would you want to mow 21 acres? Why not just let it grow? Is the acreage used for pasture?
I think a BX would be grossly undersized for mowing 21 acres unless the area in question was pretty flat and the person who was going to do the mowing had a very large amount of spare time on their hands. /forums/images/graemlins/smile.gif
   / Mowing lawn with a BX - Belly mower or Tow behind? #12
</font><font color="blue" class="small">( I do 6.5 acres with a 60" MMM and it takes me about 5 hrs to do. So for her using this set up would be really long. )</font>
Could you pull an off set trail behind mower with the tractor to give you a wider swath?
Wow! Lots of good advice as usual. The replies stirred up the gray matter, making me take a broader look at the situation. Will be traveling to Texas in Feb., and will see the layout for the first time then. Her husband admits to being mechanically challenged, so they asked me to help them look for a tractor of sometype. I'll take a wider look at their total needs and mostly likely run it by this Board again at that time. Thanks all.
penokee /forums/images/graemlins/smile.gif
   / Mowing lawn with a BX - Belly mower or Tow behind? #14
</font><font color="blue" class="small">( If you go to the main search page )</font>
Search seems to be broken right now /forums/images/graemlins/confused.gif
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
Sedan (A59231)
Sedan (A59231)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
