Mowing Mower RPM Question
/ Mower RPM Question #1
gusg
Vail, AZ
B7510 with R4s
After putting the 60" MMM on my B7500 today (it was easier than I thought it would be for the first time thanks to all of your threads) I can't remember what tractor RPM I should be mowing at. I can't find anything in the manual. I started at 2000 rpm but that seemed slow. I then remebered that last year I mowed with an RPM of about 2500. It shows the PTO 540 at this mark. Is this the correct engine RPM to run while mowing? TIA.
/ Mower RPM Question #2
I just hooked my mmm up to my 2200 today just to make sure everything worked ok....the rpm I found best was 2600. Granted I have but a 22hp but it seemed to do the trick.
/ Mower RPM Question #3
Are you talking engine RPM or blade RPM?
How do you measure either with the 2200?
/ Mower RPM Question #4
</font><font color="blue" class="small">( It shows the PTO 540 at this mark. Is this the correct engine RPM to run while mowing? )</font>
Yes.
/ Mower RPM Question #5
set your throttle at the 540 pto speed, that should be around 2500 or 2600 rpm.
/ Mower RPM Question #6
Hi Rogue:
The BX2200 doesn't come with a factory Tach so I got one called Tiny Tach from a company in Illinois. It is DC powered and has a small transponder that reads the fuel pulse in an injector line. A bit of velcro holds it to my dash. The tach on a diesel is not something you really need to look at like a sports car. I use the tach to set the rpm for the job I am doing and don't look at it until I need to change the speed.
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
2014 John Deere 7230R Tractor (A63111)
2014 John Deere...
2004 John Deere 4720 (A60462)
2004 John Deere...
