Mower Deck Stuck on Spindle
/ Mower Deck Stuck on Spindle
mrcaptainBob, I spoke to the dealers in my area and they all said to bang away, but you know, your input seams quit logical. I was thinking of pricing the parts I need to replace if I do it (cut it off). So I need to think on this one and see where the chips fall. It is definitely stuck on there pretty good.
Terry, I am going to try to move it forward a little this weekend ot later this week. I will do everything possible before using my dremel to cut it off. BTW one dealer said heat it up, then bang it. I dunno about that, and I really do not want to damage the PTO spindle.
Terry, the remaining metal collar is stuck on the spindle too. I will hit it with WD-40 again this week or Weekend and see how far I get. I plan to put some time into this weekend.
Jason, that is what I am hoping will work, lubrication and a rubber mallot - percussion-shock therapy
/ Mower Deck Stuck on Spindle #25
Nuru:
Is it possible to lock the spindle from rotating and then try and rotate the yoke with a wrench while tapping it back and forth?
Egon
/ Mower Deck Stuck on Spindle #26
Something one of the other posters said sounds like a possibility....could there be the 'remains' of the locking balls down in those holes? If they're jammed in there hard enough, I wonder if a nice titanium drill bit could get you a large enough hole that you could tap a screw extractor down in there and drag 'em out? (My wife just now looked over my shoulder and wondered why you don't do what 'I' do..."Bang-a-bang on it and 'talk' at it........")
/ Mower Deck Stuck on Spindle #27
Nuru,
Bring the tractor over here with a couple of six packs and my son and I will get that darn thing off. :)
Don
I will check that out this weekend.
I guess that could be possible have not tried it though.
Thanks, I would probabbly drink them on the way during the trip to your state!
/ Mower Deck Stuck on Spindle #31
Darn. It's getting harder and harder to get a free beer. :)
I like the option of using a cuttoff wheel along 1 side to cut most of the way through the yoke and then using a small chisel to spread the yoke enough to get it off.
Good luck on your sticky problem,
Don
I priced a replacement drive shaft assemble and it is only $125, so if I cannot get it off by banging it around, then I will chop it off, so I can cut my grass!
/ Mower Deck Stuck on Spindle #33
Nuru,
What's the prognosis my friend?
Curious to find out what you had to do to correct the problem....
Terry
Terry, I got so wrapped up in trying to get it off I forgot to report. I got to get it off the last 1/2 inch of spindle and so I am still working on it. I ordered a new driveshaft, so if I happen to do in the connector, it won't matter. I will keep you all informed!
Finally got it off. PICs to follow. I need to do some spindle spline work, as one spline was kinda flattened a bit, but I should be able to use a Dremel to make it thin enough for the new driveshaft to fit on the spindle. Right now the new unit does not go on the spindle. Oh well, I guess that is what can happen when you get a used MMM. what happened was that one of the ball bearings that secure the MMM's driveshaft on the PTO spindle got stuck and was jammed up against the spindle spline. To get it off, the cost was one of the splines was damamged - not by getting it off but by the malfunctioning ball bearing during operation. i should have caught that, but I did not, oh well, 140 bucks late, i still feel good about m used MMM purchase! Hey if it does not work i can always get a rear mount mower deck!
/ Mower Deck Stuck on Spindle #36
Glad you were able to get it off without too much damage.
Yeah, I think I can just use my Dremel with a cutting wheel to grind down the edges of that spline, so the new one will slide on. If not, then I might have to weigh the costs of replacing that Spindle versus getting a rear deck! Looks like it take quite a bit of work to remove the spindle and replace! I don't think I wanna do that!
Getting it off of my spindle was an interesting ordeal as the two ball bearings that hold it securely to the PTO spindle were seized (the other three were out) and thus they mangled a spindle or two getting them of. I took my Dremel and cleaned up those spindles and put the new unit on and the deck is quite smooth.
/ Mower Deck Stuck on Spindle #39
A little off topic but...
Did you add a turbo to your 4100 or is that just your handle? I considered adding a turbo to my NH TC45D but decided it required too much work for the extra power.
JT
Same here and so I just added it to my handle.
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
(2) GAS POWERED BLOWERS (A63745)
(2) GAS POWERED...
KUHN SR112 SPEED RAKE HAY RAKE (A63290)
KUHN SR112 SPEED...
John Deere 6200 Tractor (A64047)
John Deere 6200...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59910)
2014 HYUNDAI...
2007 MACK CXP613 (INOPERABLE) (A63569)
2007 MACK CXP613...
