Mower Deck Pulsation
/ Mower Deck Pulsation
Does the deck have holes that get covered with grass clippings?
Clippings can also build up on underside of deck and radically change the whole shape air/flow around the blade.
Last night after posting, I did a little reading on the web about mower deck airflow. In addition to learning about some interesting patents, I found a lot of info on clippings buildup causing some issues.
I had the deck flipped up last night to remove the blades to check balance. I saw a little buildup, but nothing I haven't seen before. I can scrape it off, but it's maybe an inch thick in the worst spot. It's more like a thin coating in places, no major clogs. I'll clean it out, but I'm not thinking this is the problem...it can't hurt to take care of it either way.
It sort of makes sense that the mulching blades that are designed for lift would need to move some air, and maybe I'm suctioning them down. I should probably just cut the grass a little higher, lol.
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
More info coming soon! (A56859)
More info coming...
Mini Margaritaville Truck (A55853)
Mini...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
