moving the key switch
  • Thread starter washita
  • Start date
/ moving the key switch #11
Yea well if you don't need the security of a key, the a starter button and on switch is an easy way to go. By the way most waterproof switch's are dust proof aswell probably something with a minimum rating of IP67
/ moving the key switch #12
The PT ignition switch is a generic lawnmower item. It probably cost about $2.98 I'm astounded that mine has lasted this long. When it quits, I will replace it with a DPST toggle and a pushbutton as JJ suggests.
Relocating to the ROPS is fine as long as it doesn't involve making big holes. The ROPS tubing on the 425 is just schedule 40 water pipe, not some kind of fancy chromoly unobtanium tubing. You can see by looking at it that the pipe is plenty big and strong enough to handle a simple rollover of a 1300lb machine. If you flip it off a 300 ft cliff at 80mph, you're on your own. There's plenty of margin to accommodate small screw holes for a switch bracket. You can avoid any structural concern by mounting the switch bracket to the canopy instead of the tubing.
I won't relocate mine to the ROPS. I'll just drill another hole in the control panel and use good switches.
I like J_J idea of two switches but a better switch will be my best route for safety and security reasons (12 year old nephew) thanks for the ideas and input
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
John Deere 995 (A60462)
John Deere 995...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
