Mounting mirrors on a Kubota B2650?
   / Mounting mirrors on a Kubota B2650? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Like to add a set of mirrors onto a B2650.
Wondering if anyone has done so and can post some photos.
Also, am I right in that the rops can't be folded down while
using the 3ph on this model?
   / Mounting mirrors on a Kubota B2650? #2
I put a single 3x5 mirror on the loader brace on my previous L3410.
   / Mounting mirrors on a Kubota B2650? #3
Don't have a B but still seems like the loader mount is probably the best place. You can see mine in the attached picture.
Thinking that the newer design loader on the current B series (being spaced closer to together) may pose a problem
in mounting mirrors and being able to see outside of the rear tires??
   / Mounting mirrors on a Kubota B2650? #5
You can get a set of golf cart mirrors for around 15.00 off e bay. Then add a beam clam like they use to hang conduit and hook this over the loader mount with the mirror on it
   / Mounting mirrors on a Kubota B2650? #6
Loader mount is where I mounted my own 'jury rigged' mirror. JD did offer a ROPS mounted configuration but I would've needed to take out a second mortgage to purchase one. :laughing:
I mounted it on the right arm because we drive on the left.
Are these mirrors available to purchase at JD dealers? Is vibration a problem?
   / Mounting mirrors on a Kubota B2650? #8
The one that I mounted I bought from my local Auto-parts shop. It's a 'generic' side view mirror for a van. The little JD sticker on it is something I had laying around. :)
I measured the holes and made a template using paper & took it to a local metal fabrication/welding shop. He made it out of a piece of scrap steel. I painted it JD green using a rattle-can, bought the nuts & bolts at my local hardware store. In the first picture you can just see a rubber gasket that I fashioned out of some floor matting.
The mirror does not vibrate at all... clear as a bell!
   / Mounting mirrors on a Kubota B2650? #9
Ha, my daddy use to say that people in other countries drove, "Bassackwards". :laughing:
   / Mounting mirrors on a Kubota B2650? #10
Well, steering a vehicle from the right-hand side is the traditional place... it comes from ancient ships which would steer via a specialised steering oar, which was always hung over the right side (out-board). Over time (and Anglicisation), the 'steering-oar' side got slurred into starboard.
Arrrrrrr! :pirate:
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
