Mounting mirrors on a Kubota B2650?
   / Mounting mirrors on a Kubota B2650? #1
jodebg
New Hartford, CT
Kubota B-2650
Like to add a set of mirrors onto a B2650.
Wondering if anyone has done so and can post some photos.
Also, am I right in that the rops can't be folded down while
using the 3ph on this model?
   / Mounting mirrors on a Kubota B2650? #2
I put a single 3x5 mirror on the loader brace on my previous L3410.
   / Mounting mirrors on a Kubota B2650? #3
Don't have a B but still seems like the loader mount is probably the best place. You can see mine in the attached picture.
Thinking that the newer design loader on the current B series (being spaced closer to together) may pose a problem
in mounting mirrors and being able to see outside of the rear tires??
   / Mounting mirrors on a Kubota B2650? #5
You can get a set of golf cart mirrors for around 15.00 off e bay. Then add a beam clam like they use to hang conduit and hook this over the loader mount with the mirror on it
   / Mounting mirrors on a Kubota B2650? #6
Loader mount is where I mounted my own 'jury rigged' mirror. JD did offer a ROPS mounted configuration but I would've needed to take out a second mortgage to purchase one. :laughing:
I mounted it on the right arm because we drive on the left.
Are these mirrors available to purchase at JD dealers? Is vibration a problem?
   / Mounting mirrors on a Kubota B2650? #8
The one that I mounted I bought from my local Auto-parts shop. It's a 'generic' side view mirror for a van. The little JD sticker on it is something I had laying around. :)
I measured the holes and made a template using paper & took it to a local metal fabrication/welding shop. He made it out of a piece of scrap steel. I painted it JD green using a rattle-can, bought the nuts & bolts at my local hardware store. In the first picture you can just see a rubber gasket that I fashioned out of some floor matting.
The mirror does not vibrate at all... clear as a bell!
   / Mounting mirrors on a Kubota B2650? #9
Ha, my daddy use to say that people in other countries drove, "Bassackwards". :laughing:
   / Mounting mirrors on a Kubota B2650? #10
Well, steering a vehicle from the right-hand side is the traditional place... it comes from ancient ships which would steer via a specialised steering oar, which was always hung over the right side (out-board). Over time (and Anglicisation), the 'steering-oar' side got slurred into starboard.
Arrrrrrr! :pirate:
Quick Attach Pallet Forks (A47384)
Quick Attach...
2025 LandHonor PF-11-3500G 4,000lbs 42in Pallet Fork Skid Steer Attachment (A49462)
2025 LandHonor...
71062 (A49346)
71062 (A49346)
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
