Mounting mirrors on a Kubota B2650?
   / Mounting mirrors on a Kubota B2650? #1
jodebg
New Hartford, CT
Kubota B-2650
Like to add a set of mirrors onto a B2650.
Wondering if anyone has done so and can post some photos.
Also, am I right in that the rops can't be folded down while
using the 3ph on this model?
   / Mounting mirrors on a Kubota B2650? #2
I put a single 3x5 mirror on the loader brace on my previous L3410.
   / Mounting mirrors on a Kubota B2650? #3
Don't have a B but still seems like the loader mount is probably the best place. You can see mine in the attached picture.
Thinking that the newer design loader on the current B series (being spaced closer to together) may pose a problem
in mounting mirrors and being able to see outside of the rear tires??
   / Mounting mirrors on a Kubota B2650? #5
You can get a set of golf cart mirrors for around 15.00 off e bay. Then add a beam clam like they use to hang conduit and hook this over the loader mount with the mirror on it
   / Mounting mirrors on a Kubota B2650? #6
Loader mount is where I mounted my own 'jury rigged' mirror. JD did offer a ROPS mounted configuration but I would've needed to take out a second mortgage to purchase one. :laughing:
I mounted it on the right arm because we drive on the left.
Are these mirrors available to purchase at JD dealers? Is vibration a problem?
   / Mounting mirrors on a Kubota B2650? #8
The one that I mounted I bought from my local Auto-parts shop. It's a 'generic' side view mirror for a van. The little JD sticker on it is something I had laying around. :)
I measured the holes and made a template using paper & took it to a local metal fabrication/welding shop. He made it out of a piece of scrap steel. I painted it JD green using a rattle-can, bought the nuts & bolts at my local hardware store. In the first picture you can just see a rubber gasket that I fashioned out of some floor matting.
The mirror does not vibrate at all... clear as a bell!
   / Mounting mirrors on a Kubota B2650? #9
Ha, my daddy use to say that people in other countries drove, "Bassackwards". :laughing:
   / Mounting mirrors on a Kubota B2650? #10
Well, steering a vehicle from the right-hand side is the traditional place... it comes from ancient ships which would steer via a specialised steering oar, which was always hung over the right side (out-board). Over time (and Anglicisation), the 'steering-oar' side got slurred into starboard.
Arrrrrrr! :pirate:
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2025 LandHero Universal Bucket Pins (A49462)
2025 LandHero...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2025 LandHonor BH-12-72D Hydraulic Big Arm Backhoe Skid Steer Attachment (A49462)
2025 LandHonor...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
