More UDT
/ More UDT #1
Jw5875
NW Pa.
Kubota L3400
Planning to add a BH 75 to my L3400. How much more UDT will I have to add or is the fluid part of the purchase?
jw8575
/ More UDT #2
Depends on who installs it. If you do, you get to add the fluid. It won't be a huge amount - just whatever it takes to fill the hoses. If your dealer does, they should top up your tractor. You might want to double check that...
/ More UDT #3
Not a ton of fluid, but more than just the hoses. You also have to fill the cylinders with fluid. Probably in the range of 3 gal extra, probably less. At the price of the hoe, the extra $ for the fluid has to be included!
jb
/ More UDT #5
If I was buying from a dealer I would want them to put it on teh first time just to be sure it all worked and would expect them to fill it.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
