More problems on the 425 Kohler CH25
   / More problems on the 425 Kohler CH25
Looking at more documentation, I can’t see where the “jug” separates from the block…am I missing it?
   / More problems on the 425 Kohler CH25 #102
Looks like the ch25 does not have removable cylinders
   / More problems on the 425 Kohler CH25 #103
No, it does not have jugs. It's all one block. I typed jug, and immediately edited it to say block, but it was read fairly quickly. :p
Ahhhh…I’m with you now…I’m a bit slow—more everyday! LOL
   / More problems on the 425 Kohler CH25 #105
I guess this means put it back together and see how it goes?
UPDATE: March 27, 2024 FINALLY!
Back together today and nervously gave it a crank. New tank of gas, some Choke, cranked about 5 seconds and Voila! Fired right up. It seems to be “jumping” a little at this low speed. Ran it about a minute and shut it down. During that run period I thought I heard a slight “bang” but nothing changed. I’ll attach a short video of it running. Now going to add more fuel and see if it will do a little work. 😊
For some reason now I can’t seem to attach a video..
Well…no joy. I started it again a little bit later after adding more fresh gas. It started so quick—almost the moment I turned the key! But I shut it off quickly, because I meant to check the oil. (I had just changed the oil with the good stuff before I tore it down. But wanted to check anyway.) After I cut the key and it was dying down, I hear a low pitched kind of whine that matched the motor rpms…😯Looking at the dipstick, it was almost impossible to see, and looked very thin. I’m not sure if I smelled gas in it or not, but I’m going to drain and change anyway before proceeding…
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
