More problems on the 425 Kohler CH25
   / More problems on the 425 Kohler CH25
Well…back again. After all of that work, I’m still having a bit of a problem. It starts up fine and seems to have a very slight “miss” but after warming up and putting it under a load, it gets worse—slight stumble, intermittent miss, intermittent slight backfire…got the carb pulled yet again and soaked overnight. I think I’ll go back and recheck tightness of all that I messed with before as well…🥴
Took a couple days to get it done (carburetors are the death of me lol) but after day and night soaking and in ultrasonic cleaner, so far it seems to be running well now.
And in a side note—what do you do when the float bowl gasket/rubber shrinks a little? I managed to use some small traces of superglue to tack it in place and I think it worked…
2000 Ford F-250 4x4 Super Duty Truck, VIN # 1FTNX21F7YEC45442 (A57453)
2000 Ford F-250...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
(2) Truck Steps (A55272)
(2) Truck Steps...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
