More mower problems
/ More mower problems #1
MuncyBob
Platinum Member
N Central PA
PT 422
Another problem with the 4' mower deck. I swear I'm not abusing the mower!! Just glad they are easy fixes for a welder. This is the right bracket(from driver seat) that broke yesterday. Going to have both brackets reinforced.
/ More mower problems #2
Wow, that's a clean break. It looks like the steel cracked when it was bent. I wonder if PT got a batch of bad steel or maybe changed how they bend the brackets? PT needs to know about that.
Think they'll care since the steel is over 5 years old?
Anyways, welded and back in business.
/ More mower problems #6
Part of the problem with those pieces, they are bent too tight. A bend has to have a radius. There is probably a formula, but I don't know what it is. Also, it should be bent across the grain, which doesn't look like the case, on these pieces. ?? (can't really tell from the pic.)
I did not realize steel had a "grain"...but in looking closer at the side where the paint is rubbed of I would say if what I'm looking at is a grain, then yes the bend is against it.
/ More mower problems #8
The bend should be across the grain, not running with it. So, it sounds OK.
