More mower problems
/ More mower problems #1
MuncyBob
Platinum Member
N Central PA
PT 422
Another problem with the 4' mower deck. I swear I'm not abusing the mower!! Just glad they are easy fixes for a welder. This is the right bracket(from driver seat) that broke yesterday. Going to have both brackets reinforced.
/ More mower problems #2
Wow, that's a clean break. It looks like the steel cracked when it was bent. I wonder if PT got a batch of bad steel or maybe changed how they bend the brackets? PT needs to know about that.
Think they'll care since the steel is over 5 years old?
Anyways, welded and back in business.
/ More mower problems #6
Part of the problem with those pieces, they are bent too tight. A bend has to have a radius. There is probably a formula, but I don't know what it is. Also, it should be bent across the grain, which doesn't look like the case, on these pieces. ?? (can't really tell from the pic.)
I did not realize steel had a "grain"...but in looking closer at the side where the paint is rubbed of I would say if what I'm looking at is a grain, then yes the bend is against it.
/ More mower problems #8
The bend should be across the grain, not running with it. So, it sounds OK.
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
