More mower problems
/ More mower problems #1
MuncyBob
N Central PA
PT 422
Another problem with the 4' mower deck. I swear I'm not abusing the mower!! Just glad they are easy fixes for a welder. This is the right bracket(from driver seat) that broke yesterday. Going to have both brackets reinforced.
/ More mower problems #2
Wow, that's a clean break. It looks like the steel cracked when it was bent. I wonder if PT got a batch of bad steel or maybe changed how they bend the brackets? PT needs to know about that.
Think they'll care since the steel is over 5 years old?
Anyways, welded and back in business.
/ More mower problems #6
Part of the problem with those pieces, they are bent too tight. A bend has to have a radius. There is probably a formula, but I don't know what it is. Also, it should be bent across the grain, which doesn't look like the case, on these pieces. ?? (can't really tell from the pic.)
I did not realize steel had a "grain"...but in looking closer at the side where the paint is rubbed of I would say if what I'm looking at is a grain, then yes the bend is against it.
/ More mower problems #8
The bend should be across the grain, not running with it. So, it sounds OK.
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2013 Komatsu PC210 Excavator (A60352)
2013 Komatsu PC210...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2011 DOOSAN G25KW GENERATOR (A60736)
2011 DOOSAN G25KW...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
