Montana 3040 Electrical Question
/ Montana 3040 Electrical Question #1
Woodsman30350
Texas
Montana 3040
I have a Montana 3040 that I am trying to obtain information on the 6 wire connector at the rear of the tractor that I assume is for trailers of other devices. I has black, white, green, red and two yellow wires. I want to connect my 12 foot utility trailer and any information will be appreciated.;
/ Montana 3040 Electrical Question #2
I'd probe the contacts with a volt meter and play with different things on the tractor to figure out what's what.
My wild guess:
black - power
white - chassis ground
green & one yellow - turn signals
red & other yellow - no idea, maybe lights & reverse?
/ Montana 3040 Electrical Question #3
there are power wires there that operate with the light switch, i added 2 led work to my rops and connected to the wires i probed out.
/ Montana 3040 Electrical Question #4
My Branson has a 7 pin;
it is set up for a european 7 pin and their trailer wiring.
/ Montana 3040 Electrical Question #5
Do you perchance have an owner's manual identifying the connector as being for a trailer? If you do it should identify the pins within the connector.
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
