Mold and grass buildup on mower deck underside
   / Mold and grass buildup on mower deck underside #101
I have a 2007 Gravely commercial zero turn. I use my blower to blow off the top of the deck after every mowing, but I have never needed to clean the underside of the deck. I mow wet grass all the time. The statement above about not all decks are created equal is certainly true. The underside of mine is always clean bare metal.
   / Mold and grass buildup on mower deck underside #102
The most ingenious thing a saw was a guy's deck that he inherited from his dad or gramps when they passed. He had meticulously done a bed liner under a rider deck. Prepped down to the shiny steel. I dunno that it did much for the sticking issue, but was done to preserve the housing.
I did this to my grooming mower. It worked well for preserving the deck and made it easier for cleaning it off with a hose/pressure washer. Scraping it can be easier if I remember not to scrape down past the liner. So far I’ve done good and haven’t had to recoat it after five years.
   / Mold and grass buildup on mower deck underside #103
Do you have a pond on your property? Saw a YouTube video not long ago of a guy who back his rotary mower into a pond and engaged the PTO...seemed to clean everything underneath the mower pretty good!
   / Mold and grass buildup on mower deck underside #104
I try to avoid mowing wet grass, but sometimes that just happens. Regardless, wet or dry, after mowing I pull up over a small pile of wood chips from my wood chipper, and let the mower clean itself for a minute or so. The wood chips are small enough to not damage the mower nor blades, but good enough to knock off any clumps of mud, grass, etc. from the mower underside. YMMV
No pond or wood chips, but I do have a bunch of rubber mulch, which would have the same effect as the wood chips, hard enough to do the job, but soft enough to not damage the brand new blades. Finally got the deck back together, now just need to wait for the grass to dry up before I mow it again. And once finished mowing, put up on the lift and scrape it off.
I borrowed a friends mower while mine was down and his deck had a lot of stuck grass on the underside too, made me feel a little better about mine.
   / Mold and grass buildup on mower deck underside #106
Guy across the road nad a seond hand Husky ZTR tha mje flogs on regularly. Ki9nd if surprised it actually runs as Husky mowers are top tier amyway. Everytime hw mows it's always we and cut close and makes cud and right now looks like a mini hayfield with brown windrows and the cud will kill the grass underneath as it sits there. Not mine, I do find him 'etertaining'. Actually amazed the mower even runs, he never changes the oil or changes the blades, that I know of. I know the battery is short as he has to jump start it every time and goes at full throttle, always. He drives his car the same way.
2386 (A60432)
2386 (A60432)
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
