Tires Molasses filled tires
   / Molasses filled tires #21
I have rimguard in my L3400, and it works great. I had the cal in an IH, it rotted the rim pretty bad.
   / Molasses filled tires #22
Well, I called my dealer back and he said it was rimguard. That is kinda a let down that maybe my tractor isn't as sweet as I thought. He said he just likes to call it molasses because that is what it is like to him. I asked him how much to fill my 13.6x28 tires on the AC WD - $3.25 per gallon and he said I could put in as much or as little as I wanted - is there a reason not to put in the full 86 gallons besides cost? It would seem to me that the more weight the better. I am wanting to use the tractor to pull a 3 bottom plow, a 9 ft disk, a 2 row planter and a hay wagon. There may be times I want to trailer it to a show, but I don't have a trailer yet, so I would get one capable of hauling it and any attachments I may want to take.
Your tires dont take 86 gallons to fill, my 16.9x28 tires only take 69 gallons to fill. There is a chart on the rimguard website that tells how many gallons you will need.
   / Molasses filled tires #23
here you go
13.6-28 43.0 460.1
43 gallons each and 460.1 lbs each
(Based on 75% Fill Level/Valve Stem at 12:00)
according to the rimguard chart.
James K0UA
Ya, but there are 2 of them and 43x2=86.
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
Zero Turn Mower (A59231)
Zero Turn Mower...
Deere 333E (A60462)
Deere 333E (A60462)
