Sprayer Modifying 55 gal sprayer
/ Modifying 55 gal sprayer #11
Why not put a quick couplings on your outlet. Put males on boom and handgun and female on pump side. That how I change back and forth
Forester, That sounds like a good solution. Where did you get your couplers??
Thanks for your advice. Forester, what type quick couplers are you using. I have used ones for garden hoses before. Is that the type you use?
/ Modifying 55 gal sprayer #15
I've got a similiar situation but I'm not doing a controlled burn I just don't have any major water on my property except for a windmill. Before I get too busy I'm in the process of making a fire wagon/trailer of some kind (2 or 4 wheel) using from 2 to 4 of the 275gal totes. I've already purchased 2 at $80 apiece and a small gas powered water pump to pump into a couple of 3/4in hoses (most likely 100ft each). They'll be filled and ready at all times all I will need to do is hook up to truck or tractor. That should hold me until the fire department can get there.
Good luck.
1762 (A58375)
1762 (A58375)
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2021 International RH163 T/A Day Cab Truck Tractor (A59230)
2021 International...
