MODIFY BRUSH HOG SOME MORE
/ MODIFY BRUSH HOG SOME MORE #121
3RRL said:
Pat, yeah I could change over the wheels for a bigger print too, but then I'd need to get other wheels. I want to use the same Quick attach wheel system for everything... at least that's what I'm attempting to do.
I'll draw up a couple of ideas.
You are intending to only have one set of wheels, right? Will having a larger footprint inhibit the working of any of the other implements? In soft freshly worked dirt little wheels can sink in quite a bit and then when hitting harder dirt suddenly get more "flotation." A larger footprint will tend to "swamp out" that effect.
Pat
Pat
The wheels have to work on the back of the rotary cutter. I don't think inflated wheels would last long after the first cut of rocks sending shrapnel to them. The other consideration is my budget. That means buying more wheels. I'm still trying to keep within my low budget goal by using what I have ... as low budget as possible. So far I have managed. They may not be the greatest wheels, but they are like 15" in diameter and 4" wide tread.
Well, I figured out a way to drill the holes in the quick attach wheel base. Here it is with the holes on the side. I draped it over my milling machine and rotated the head over to one side. Then I primered it, but kept it here at home so I can match the receiver bases for the rotary cutter and the boxbalde to be sure they will line up and fit properly.
Then I went up to camp with the other pieces.
I brought up all the other pieces including the 2 x 2 tube that I slit in half to make the reinforcement for the rotary cutter body. Here they are laid on top of the rotary cutter. But before I could weld them on, I had to cut them to length and also notch out the ends where they overlap the angle iron on the cutter. I did all that with my Harbor Freight portable band saw that I bought last year but have never used before. I got it on sale for like $49 bucks back then. If anybody is interested in how that worked, I'll post a review about it. It was sweet to easily saw steel at camp for a change.
Anyway, after I cut the reinforcing bars I welded them to the rotary cutter and primered them. It made an immediate difference as to the sturdiness of the body.
I also finished painting the other part of the quick attach wheels, then assembled and greased that part up. The Zerk fitting work I did came out nice to lube the pins and bushings. Now it is ready for the base part which is still at home.
The receiver base for the boxblade will have to be different than for the rotary cutter, since the two implements are different height. I might make a spare receiver base for when I make a rock or landscape rake. I'm thinking it will be about the same height as the boxblade. After I make the receiver bases for each implement, I'll bring all that up and work on plumbing the hydraulics at camp.
/ MODIFY BRUSH HOG SOME MORE #126
I bought one of those Howse lightweight bush hogs used and abused. The gearbox mount cracked, the bolts got loose, and cracked it some more, and the blades created a circular pattern on the deck. I used flatbar on edge to reinforce it the same way you are, except I ran the flatbar back to the point where the side ends and the rear angle starts. Thought that might give it more stability, but who knows, since I rebuilt it for a guy to mow shooting lanes with it. I used 1/2 inch plate as the base for the gearbox mount, and two pieces of flatbar on edge to create a piece of channel out of it. I was going to use a Volstro Rotary head to make the gearbox hole, but my buddy grabbed a torch while I was getting the Volstro out of the box. He doesn't understand the fine art of a nice milled finish, (but he is good with a torch).
Keep an eye on that formed channel mount for the gearbox, as it is only 3/16" thick on the 6' mower I had to fix.
David from jax
/ MODIFY BRUSH HOG SOME MORE #127
Regarding the gauge wheels on your box blade sinking into the soft dirt. Would not your position control take care of that condition at least on flatter more even ground? Does your tractor have draft control?
Just wondering
David,
That center gearbox mount plate is pretty thick on mine, thicker than 3/16" for sure and more like 3/8" thick. The angle iron is 1/4" thick. Anyway, I'm hoping for the best with the added reinforcing. My wheel mount base will also add more.
Just wondering
Yes, both position and draft control, so I can use the position control to lift the entire cutter if I want. I could set it so it sinks a little but not too much. After a couple passes, I'll let the wheels take over. So yes, you are right.
On the other hand, I've gotten pretty good with my boxblade and so far I haven't needed them. I've read so many threads about having gauge wheels on them or back blades that I decided to make the wheels so I could use them on the boxblade instead of just on the rotary cutter. I'm making the Quick Attach Wheels mainly to be more versatile ....so I can use it on other implements if I want.
/ MODIFY BRUSH HOG SOME MORE #129
Rob, been following this project, as a spectator, since it's inception. I have two comments:
First, I'm green with envy at not only all your equipment, but at your ability to use the same. IMHO, you've created art.
Second, concerning your reinforcement of the mower deck, I'd have continued the "over-kill" by adding pieces between the ones you added because knowing my luck, making the outboard area of the deck stronger, it would fail, catastrophically, in the center.
Keep up the good work, I'll be watching, & thank you for sharing!
David,
Thanks for the kind words.
I was looking at those other sections too. One thing is I will be adding a flat plate from the center to the rear. They are 3/8 thick and 4" wide 'cause that's what I've got in the scrap pile. On those flats is where the base mount will be welded. So that should help too.
I got the dog leg design for the boxblade to where I like it and it will not hang over the back of the box, so I can use my rear blade when not using the gauge wheels. As I explained above, the boxblade (and future rake) receivers will be two pieces. A tube which will be welded to the box blade and remain part of it, and a dog leg piece to let the wheels touch the ground and have 5" or 6" adjustment. the Quick Attach Gauge Wheels will sit on the dog leg part.
When not in use, I'll take the wheels and the dog leg off.
Here's my idea.
I got the steel tube already and need to slit it in half, but had to buy the dog leg pieces and also the base for the rotary cutter. They didn't have the solid steel pieces in the scrap section so I had to pay full price ... set me back $180 bucks. But divided by three implements, that's getting a set of hydraulic gauge wheels for only $60 bucks a piece.
They were not part of my original design, so I'm not gonna count that towards the Rotary Cutter project, but rather a separate project since the wheels can now be shared among all kinds of implements....sound fair?
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2015 LAND ROVER RANGE ROVER EVOQUE (A60736)
2015 LAND ROVER...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2007 LAREDO 5TH WHEEL (A60736)
2007 LAREDO 5TH...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
