Model Numbers
/ Model Numbers #1
bota7800
Washington State
Kubota B7800
I am considering getting a little larger tractor with cab-air-heat.
Is there any rhyme or reason to the JD model numbers? Here are some examples. I know someone with a 4440 - it is over 100 HP. I looked up a couple others in ads. A 4410 is 35 hp and a 4310 appears to be a large garden tractor.
Where do I get my secret decoder ring? ;)
/ Model Numbers #3
JD 4310, very large garden tractor:
/ Model Numbers #5
bota, the 4440 you refer too is over 20 years old, the new lineup JD has would make that something like a 7300 series. JD changes their numbers once and a while and there is overlap, it's a bit annoying to try and decipher sometimes. you're best bet is to figure out the h.p. rating you want to be at and then go to their website
/ Model Numbers
To be clear, I was just using those model numbers as examples of similar numbers for very different tractors. Thanks, traprat, I will look at tractordata.
/ Model Numbers #7
The numbering system for non-current models is very confusing. If looking at new models the numbering systems isn't as confusing as it used to be.
2000 series - small frame Compact Utility Tractor (Some people may call these "Sub-Cuts")
3000 series - Mid Frame Compact Utility Tractor
4000 series - Large frame Compact Utility Tractor
If the model # ends with '05' it is an economy model designed to meet a price point with few upgrade choices.
If it ends in '20' then it is a normal model with all types of engine and drive options.
Cabs are available in the 3000 and 4000 '20' series
/ Model Numbers
Thanks turbo36. I looked at a 3000 series cab at the Stock Show last month. Very nice.
/ Model Numbers #9
3 series are the same size as your 7800.
If you want larger, the 4 series is the one for you.
/ Model Numbers #10
The 7800 and 3 series are comparable only in terms of HP (with respect to 3120, other 3 series have higher HP). The 3 series is a wholly different and larger frame machine (2900lbs vs 1740lbs for 7800) and higher capacity (examp: 2200 lbs 3ph lift vs 1300). If I'm not mistaken, the 7800 is more like something between the 2320 and 2520, perhaps even a 790. The 4 series will be a big jump up.
