Model Numbers
/ Model Numbers #1
bota7800
Washington State
Kubota B7800
I am considering getting a little larger tractor with cab-air-heat.
Is there any rhyme or reason to the JD model numbers? Here are some examples. I know someone with a 4440 - it is over 100 HP. I looked up a couple others in ads. A 4410 is 35 hp and a 4310 appears to be a large garden tractor.
Where do I get my secret decoder ring? ;)
/ Model Numbers #3
JD 4310, very large garden tractor:
/ Model Numbers #5
bota, the 4440 you refer too is over 20 years old, the new lineup JD has would make that something like a 7300 series. JD changes their numbers once and a while and there is overlap, it's a bit annoying to try and decipher sometimes. you're best bet is to figure out the h.p. rating you want to be at and then go to their website
/ Model Numbers
To be clear, I was just using those model numbers as examples of similar numbers for very different tractors. Thanks, traprat, I will look at tractordata.
/ Model Numbers #7
The numbering system for non-current models is very confusing. If looking at new models the numbering systems isn't as confusing as it used to be.
2000 series - small frame Compact Utility Tractor (Some people may call these "Sub-Cuts")
3000 series - Mid Frame Compact Utility Tractor
4000 series - Large frame Compact Utility Tractor
If the model # ends with '05' it is an economy model designed to meet a price point with few upgrade choices.
If it ends in '20' then it is a normal model with all types of engine and drive options.
Cabs are available in the 3000 and 4000 '20' series
/ Model Numbers
Thanks turbo36. I looked at a 3000 series cab at the Stock Show last month. Very nice.
/ Model Numbers #9
3 series are the same size as your 7800.
If you want larger, the 4 series is the one for you.
/ Model Numbers #10
The 7800 and 3 series are comparable only in terms of HP (with respect to 3120, other 3 series have higher HP). The 3 series is a wholly different and larger frame machine (2900lbs vs 1740lbs for 7800) and higher capacity (examp: 2200 lbs 3ph lift vs 1300). If I'm not mistaken, the 7800 is more like something between the 2320 and 2520, perhaps even a 790. The 4 series will be a big jump up.
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
2004 CASE CX75SR EXCAVATOR (A65056)
2004 CASE CX75SR...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
