Mobile home
/ Mobile home #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Hello and thank you for your time.
I am considering placing a mobile home on my property. I have been given the authority by the county. I know nothing about mobile homes.
I have been told it needs to be 1976 or newer, has to have a title, minimum of 500 sq ft, has to be hud approved and wind loads of 2-3 whatever that means?
Can someone educate me on mobile homes? Anything you can tell me would be more than I currently know.
/ Mobile home #2
single or double wide, there cheap built using mostly particle board, most are not setup properly, ac/heat trunks rot out and leak, known to have plumbing/water leaks
which lead to floor rotting, bath tubs and shower stalls are plastic made, not safe in wind loads above 70 mph, just cheap all around.
/ Mobile home #3
Mobile “Mansions “ are money pits and you will regret every day that you own one.......I know from experience!
/ Mobile home #4
Lived in one that was built in 1996. Still going strong, but also took about a year of looking to find one that i thought was a good deal. Some things are different from a stick built. Not had any of the problems that Mike apparently is having.
If i had more money at the time, i would put in a stick built house. It doesn't hurt to get to know some house building terms and how houses are built in general. So for instance, how much of an overhang the roof has, pitch, how the joist are made. Exterior and interior wall construction. What type of water pipe is used. Don't assume anything, spell it all out, for instance are all interior doors included at that price. They will try to snow you with BS and quick talk, nail it down. Good luck because there are a lot of good mobile homes and probably more like the one Mike is talking about.
/ Mobile home #5
I've found that the Mobile Home industry has come up with some of the very best floorplans you can ever have in a rectangular shaped building. The newer models have also gone all out in making them extremely attractive with some very nice finishes.
Having worked on quite a few of them for clients, I've also learned that they have figured out every possible way to cut a corner that there is. From going with the cheapest electrical outlets ever invented, to the bare minimum in plumbing to the lightest framing allowed. They are a fast and cheap way to have a place to live, but the also lose value every year. If you pay $50,000 for it new, you will never sell it for that amount in the future unless you do something with the land to make the overall property worth more then the mobile home.
My ex was a title officer and she worked with several local mobile home companies. Their business plan relied on repossessing a brand new mobile home 3 times before selling it for the last time. They provide financing that they know the buyer cannot afford, so they plan on getting as much upfront cash as possible, then taking the mobile home back and selling it again when they fail to make their payments.
/ Mobile home #6
As a counterpoint to some of the above posts....
I've been living in a doublewide for the past 30 years now. Never had one leak in all those years. Or other problems that I can think of. 6" exterior walls with what at the time was called the "Alaska" insulation package, and triple pane windows. Factory-installed wood-burning stove which last year I changed out to a pellet stove. A few years ago the original shingles on the roof were starting to curl so I had a full metal roof put on so I'd not have to worry about it again in my lifetime. And this year I changed out all the original faucets for fancy new ones - also the frost-free sillcocks in the outside walls.
And there is NO particle board in this house of mine. Inside walls are sheetrock. I think some folks are talking about old single wide mobile homes built in the 60s and 70s when they talk about the construction. Also - mine sits on a full basement. Concrete walls/floor with I-beams to support the house. Lots of storage - and if ever I do have to do something with the plumbing like changing out the sillcocks, I can do it on a stepladder instead of lying on my back in a crawl space.
/ Mobile home #7
In 2003 we bought a new double wide with 3 bedrooms & 2 baths. It has 6"walls fully insulated, dual pane glass and all the appliances were our choice. We lived in it for 6 years and it was the most comfortable and economic home we have ever owned.
We moved because the area grew from a small rural area to a city of 150,000 and we were annexed . I couldn't stand it any more so we moved but kept that place as a rental and have had no problems except those caused caused by one renter who was a nightmare. The current tenants have been there 8 years and would like to buy it.
You have to be very careful in shopping and look at every detail including the contractor that does the foundation, but they can be a very good buy. We had a neighbor who put in a larger place when we put ours in and they still live there with no complaints.
/ Mobile home #8
Are some here conflating "mobile homes" with "modular homes"?
/ Mobile home #9
It's all in how you spec them out. If you just go to a mobile home sales lot and choose the cheapest thing they've got...then that's what you'll have. If you go to that same lot and have them build the home the way YOU want it you can get something a lot better.
I don't know what the difference really is between a "modular" home and a "mobile" home other than how it was spec'd out. My mobile came to me on 8 axles (4 for each side). Four years later those same axles were put back under the house and it was moved to my present location. I still have the axles and tongues so I consider it a "mobile". Whatever, the quality has not disappointed me in the 30 years I've owned it.
/ Mobile home #10
Hmmmm "mobile" is a very different word than it once was. Everything is mobile, it seems these days. :)
I have lived in a tiny house on wheels for the last few years. But it certainly won't meet that 500sf minimum.
/ Mobile home #11
Most people consider a mobile home as a trailer. It is built in a factory, set on wheels and trucked to a site. There it is blocked up, and the wheels are removed. It can easily be moved at a later time.
A modular home is usually built in a factory in pieces. The sections are trucked to a site and placed on a foundation. Generally, they are not intended to moved again.
This is also my understanding. When we bought ours we toured several different factories and pretty much designed ours to our specs.. Before it was delivered we hired a contractor who specialized in these and he had the footings and foundation ready to go. They delivering company placed the units on the foundation, did any fine tuning on the leveling, using a water level. They then removed all the running gear and the tongues. They took the axles and wheels etc. but left the tongues and said they cannot be used again and I could do as I pleased with them.It was then considered by the county to be a permanent structure. The modern version of a mobile home is now known as a manufactured home.
There is a law in that county that an old style mobile home with aluminum siding, roof and running gear cannot be moved and set up. Most of them end up in Mexico,
/ Mobile home #12
...Can someone educate me on mobile homes? Anything you can tell me would be more than I currently know.
The most important thing about a mobile home is where you place it on your property...you should put it as far away as possible from anything that could be damaged by a tornado...!
/ Mobile home #13
(yea, I'm that guy. My tractor cost more than my house) View attachment 681422
Looks like your car cost more than your house. Living in a camper is a code violation here.
/ Mobile home #14
Are you talking about a mobile home, or a manufactured home? There's a huge difference.
Manufactured homes are stick built in a factory. Very similar to built-on-site. Mobile homes, on the other hand, have wheels, axles and a tongue and are, well, mobile.
/ Mobile home #15
I was wondering the same thing.
Modular. Manufactured. Both are pretty much stick built houses, just built on a production line in a factory VS on site.
Mobile homes are very different.
/ Mobile home #16
Iceland has never recorded a tornado!
Maybe a good place for a mobile home?
/ Mobile home #18
Well then he shouldn't have anything to worry about if he ever leaves FL and moves to Iceland...! :laughing:
now go take your meds...!
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
Bobcat T590 (A60462)
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
