ML112 FEL Issues???
/ ML112 FEL Issues??? #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
After my new 78" bucket fell off last week for the second time while doing some relatively easy work in my backyard, I decided to take some comparison pix and post them here for "4110/3510 User's Group" input... plus, of course, professional-grade input from Jeremy :) Specifically, I'd like anyone with an ML112 loader to look at the following pix and tell me what you think of: a) QA Pin & spring alignment (seems straight on left, big angle on right), and b) Lower QA "foot" seating (seems flat on left, not flat on right). Both *right side* issues seem a heckuva lot better, straighter, flatter and more secure on the brand new 2006 ML112 I found down in Connecticut this weekend. I'm wondering if I have broken parts and/or a bent QA mount? :confused:
My ML112:
A brand new 2006 version ML112:
4110/3510 User's Group... and my good friend Jeremy: Your comments please! :)
Dougster
/ ML112 FEL Issues??? #2
Dougster, looks like you might have a set that is on the outside side of manufactures tolerances.:( Would you take some pics of your setup that would be duplicates of the ones you took at the dealers and post? Then we can see side by side the differences. Not just looking from different angles.
Later
Later
Not sure if you are goofing on me or are dead serious! :D Do you know how long it took me to make up these mirror image "left vs. right" closeup composite pix??? :eek:
BTW, the pix of the new 2006 were the best I could do after hours at that CT dealership. No one was there to start it up and raise the bucket. Maybe I should have brought along my generic 4110 key! :)
Dougster
/ ML112 FEL Issues??? #4
OK, take a picture of the messed up side, but at the same angle (position) as the one from the dealer. Easier to actually see the difference then.
I need to go out and do something & get off the computer.
Later
/ ML112 FEL Issues??? #5
Mine is exactly the same. I bought mine from a Mahindra dealer in Florida a couple years ago as a matched set. They had to order it from KMW. I adjusted the spring tension on that sticky pin as tight as it would go and just have to tap it down sometimes. It's gotten better with use. I have a slightly greater clearance than yours on that right foot - I had to drill a hole in each foot thru the adapter and bucket foot and inserted a hard pin. This will keep the bucket from coming off when back-dragging or.... It's an extra step when changing buckets, kinda takes away from the "quick attach" convienence but it's easier than trying to deal with getting it corrected thru Mahindra or KMW. I believe it is in the adapter itself, I bought a univ. skid steer plate for my old bucket from a totally different manufacturer and it fits the same way, had to drill the corresponding holes in those feet too. In my opinion, KMW is ultimately responsible for lack of QC.
Fair enough! :) Ask and Ye shall receive:
Looking straight at the right side pin and spring (note angle vs. brand new):
Looking up at the right side pin and spring:
Looking at the lower right side seating gap:
Dougster
Hi Skip - I remember us talking about this a long time ago in regard to my old 72" light-duty bucket when it came off during some serious dirt road backdragging right after I bought the Beast. My new 78" HD bucket came off while pushing over and crunching up some relatively small trees... twice in one hour!!! :eek: Doesn't seem that it was very hard duty. :rolleyes: It had come off once previously, but I must have done something wrong myself that time... perhaps caught a root on one of the levers... because after it dropped off, I noticed that one QA lever was nearly a third open. :eek: I wrote that up as my fault for not noticing. :(
Extra pinning just doesn't work for me. If this was for personal use only and I only had one bucket... fine. But not for multiple QA attachments and use away from home. Very embarrassing to drop a bucket in front of a customer... or have to tinker with auxiliary pins. :eek:
Dougster
/ ML112 FEL Issues??? #8
What timing, just came in to get some dinner. I think that from your current pics, you should not be having any problems. The mating surface is off a little, (1/8"?) but not enough to be a problem I would think.:confused: As long as the pin is locked down to its lowest position, it should be alright even with the pin & spring at a bit of an angle.:confused: By chance were the pin, pins not engaged completely when it came loose? I was back dragging once with my grapple and it came off on one side.:eek: Man I would have been in trouble if both sides had come loose.:eek: Anyway has not happened since, chalked it up to not checking stuff out before using it.
It's cool:cool: that you have grease fittings for your pins, I don't have any on mine, or I don't think that I do anyway.
Not sure what to tell you other than to be careful. Hey, I just looked at your pictures again and you clearances have changed. In the 1st pic there is over 1/4" gap, maybe 5/16" and in your last pic it looks like about 1/8". Is the bucket not seating properly? Something else to check. Now hard are your pins to lock down? Mine are relatively easy, or things aren't lined up right.
Pins are generally quite easy to latch down when everything is aligned properly. The changing gap you are seeing is probably a combination of two things: a) an actual gap change based on the positions (angles) the bucket was in during the two picture sessions and, b) an optical illusion based on camera angle and daylight vs. the shadowy darkness of my garage! :) The bottom line is that there is an obvious gap on the right side... that may vary slightly based on bucket angle... and no gap whatsoever on the left side.
Dougster
/ ML112 FEL Issues??? #10
Dougster,
Here are pictures of mine.. something defintely looks out of kilter with your right one.
mboulais said:
Dougster, Here are pictures of mine.. something defintely looks out of kilter with your right one.
Hi Marcel - Thanks very much for the pix! :) And yes, I agree. Your right side looks perfectly straight... just like the brand new one. Time to take mine apart and see what's up before another unscheduled bucket drop. :eek:
Dougster
/ ML112 FEL Issues??? #12
My right side QA pin has always been harder/tighter to lock down but goes far enough down to catch. Have'nt dropped the bucket back dragging yet.
But the question is... Does it stay straight... i.e., perpendicular to the ground... like Marcel's and the brand new 2006??? Or does it end up at a funny angle like mine??? :confused:
Dougster
MtnViewRanch said:
Houston, we have a problem. Sorry that I can't help.:( Good luck.:)
Well, you could always sell me your USED BLUE 7520 at a nice bargain price... yes??? :D
Dougster
p.s., 1,000 posts! I just became a "Veteran Member" :) And most of you folks have forgotten more than I will ever know about tractors and the like!!! :D Funny how that all works, heh? :) -d
/ ML112 FEL Issues??? #16
Dougster
Im really not sure?
I need to go and look at it.
/ ML112 FEL Issues??? #17
Dougster
First off, congratulations on your 1000th post.:) I know that you want a 7520 bad, but an old used one that some knucklehead painted blue?:rolleyes: Besides, I thought that your 4110 was on the big side in your neck of the woods, what wood you do with a 7520 anyway? You won't make any $$$ playing in the back yard.:) I would like a bigger utility tractor, but the problem is that you have to go up several sizes before you get to one that is much better than the 7520, and they are biiiig money.:( Way out of my price range, so for now I will be staying with what I have. I would like an additional 40hp tractor though, maybe later.;)
It's just a matter of time Brian... just a matter of time! :D
2005 MAHINDRA 7520 For Sale at TractorHouse.com
eBay: Mahindra Tractor 2005 7520 4WD (item 280126593877 end time Jun-25-07 17:22:55 PDT)
Dougster
/ ML112 FEL Issues??? #19
MtnViewRanch said:
That tractor is just a few tractors before mine. I have the current style of bucket though.:)
Heckuva good price with the loader and only 300 hours... and right down the road in New Jersey. :rolleyes:
I could practically drive it home... as long as I didn't get another nosebleed!!! ;)
Awfully dang tempting Brian... awfully dang tempting!!! :D
Dougster
