Mitsubishi 210D hydraulic control
/ Mitsubishi 210D hydraulic control #1
pafarmerbecky
I am trying to find a scematic for the hydraulic control layout on the Mitsubishi 210 D tractor. I have a 1990 and have suddenly lost the ability to lift any rear attachments. I am unable to see if or where something broke. Any help would be greatly appreciated. Thanks!
/ Mitsubishi 210D hydraulic control #2
I am assuming this tractor is a MT210(D). Do you have a front end loader
on this tractor? If so does the front loader work? If you do not have a
loader on this tractor you should check to see if you have hydraulic pressure
to the rear lift. Follow the pressure line from the hyd. pump to the rear lift top.
Open the banjo bolt a few rounds to see if you have pressure with the tractor running at idle so it doesn't splatter everywhere. If you do not
have pressure, it could be a clogged screen filter on your left side (cylindrical
tube with cap)or a bad pump. If you are getting pressure(tighten banjo bolt or shut tractor off to tighten bolt) than you have some debris stuck inside the lift control valve body.
There is no parts cost to fix this if you are getting pressure to the rear lift.
The valve body just needs to be cleaned. There's just alot of disassemling.
If you would like for us to walk you through it, you can contact us at 903-603-9171.
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
(2) 5' TRAILER RAMPS (A60430)
(2) 5' TRAILER...
