Mitsu Beaver III 480?
/ Mitsu Beaver III 480? #1
Griswald
Mitsubishi Beaver III Satoh 480
Father n Law is giving me a Mistu tractor w/ front end loader. I only have pics to go on at this time and am trying to find more info on it and possibly a svc manual. I did a search in this forum for a Beaver III 480, but nothing comes up. Can anyone help me identify this machine and point me in a direction to find the manual and any info on this model?
Thanks!
/ Mitsu Beaver III 480? #2
A Beaver III would be a 373. A Buck would be a 470. Never heard of a 480. The 480 decal is not original. I bought a set of manuals for my 470 and they cover the 373 also. They are the same except for engine size. Got my manuals at www.satohparts.com
/ Mitsu Beaver III 480? #3
I'm inclined to say the "480" you're looking at is a unit number, possibly from a rental facility or something. The Beaver III is an S373 by Satoh, parts and manuals are available from Valley Power and some others. The tires are mismatched, obviously; you'll be wise to make sure they're the correct size for the drive ratio.
The maintenance parts for my Japanese market equivalent were simple to find, though I don't recall offhand what filters they took. A search here will reveal the correct part numbers. Napa had them in stock, and the fan belt was simply matched by size.
I run 5W-40 synthetic motor oil in everything I own, from pickups, ATVs and dirtbikes to tractors, ski boats and crotch rockets, but any 15W-40 diesel oil is fine too. The hydraulic fluid will be universal tractor fluid, something that meets John Deere 303, IH Hy-tran, or equivalent will be correct. It is hard to tell, but the loader may have a separate reservoir and pump; make sure to check that fluid as well, and change it if you do the rest, too. The front axle will take gear oil. A service manual will tell you exactly what, but I got a deal on a case of 85W-90 synthetic, so run that in my machines.
Any high quality coolant should work at 50/50 ratio, (I use whatever is on sale, and dilute it to 50/50 with distilled water) but I like to run a little surfactant (Water-wetter or equivalent) and do a flush of the system first, just to be safe.
/ Mitsu Beaver III 480? #4
Oops, I see I started writing just before Oliver responded. Sorry. Thinking on it for a few minutes, I believe the oil filter was a Napa 1334; there are equivalents from other manufacturers as well (The Fram variant is the 3593A). That filter fits all of the small Yanmar and Mitsubishi tractors I own.
Great info! Thank you both for your time to reply.
Any idea what this tractor and front attachment might weigh?
/ Mitsu Beaver III 480? #6
Not really sure about the weight, but based on evidence in your first pic, if your tractor would curb its drinking problem, its weight would surely go down...
/ Mitsu Beaver III 480? #7
Tractordata.com lists an S373 at 1235lbs, but doesn't have any other specifications really. However, the previous version, the S370, is specified to weigh 1179lbs in 4wd. With the loader adding a couple hundred pounds, as well as wheel weights, I would guess you're somewhere around 15-1600lbs, at least. Filling the tires with calcium chloride or beet juice would add another couple hundred or so pounds.
/ Mitsu Beaver III 480? #8
My beaver III had a sticker/decal on the left side of the tractor (sitting on the seat) just above the front axle on the frame rail Listing the model.
