Missing spring? Yanmar 169D
/ Missing spring? Yanmar 169D #1
Nocturno
Winnipeg, MB Canda
169D Yan
Hey everyone!
Anyone else with a 169D, or someone that would know.
Attached a picture of my tractor, and a zoomed in picture. I think I am missing the governor spring, but I can't find any pictures of this area online.
If you have a 169D and can attach a pic of the same area, or if you know what part I should be looking for please help me out!
There is a ushaped flange/bracket and a block with holes in it that rotates. Seems like a spring would reach here.
/ Missing spring? Yanmar 169D #3
Hey everyone!
Look at the parts manual link Winston gave. Now, look at the section for the fuek pump too.
Does then engine stall ir not idle? Then look at the thrittle lever friction discs to replace or beef up.
Ok, not trying to be dumb on purpose, I went through each diagram multiple times, couldn't find the diagram highlighting this area.
But I will keep looking.
I noticed when rototilling it will just give up, and won't recover even if you manage to clutch before it stalls. It will just sit and idle even though the throttle is full open. So I shut it off and start it again, and it starts to have full power again.
Or it takes quite a long time to recover. Also won't idle lower than 1000, which some times you can get it to recover by pushing the throttle back up, other times no.
Edit:
So it looks like the engine stop device? And there is nothing between the lever with the rotating box, and the flange/bracket?
/ Missing spring? Yanmar 169D #5
Edit:
FIrst, is the fuel fresh and a new fuel filter, bowl and o-ring? Old fuel and semi clogged injectors can cause your issues. If all that is resolved, the fuel pump and governor rack will need inspecting. The best person for this is member thepympguysc .
I change the fuel filter every spring. Fuel is most likely never more than 1 to 2 months old. I buy a barrel and add in the 1L of
Kleen-flo Diesel Conditioner, run the same fuel in my 1070 Case.
I put a new bowl and O ring on it I think 2 Springs ago.
The setup for in the third picture sure looks like a cable or a spring of some kind, but I can't find it in the manual. I've looked at it till my eyes crossed at this point. Like a cable being held in the flange.
Anyway appreciate the leads.
/ Missing spring? Yanmar 169D #7
I don't know where you are located but if you look at figure 40, item 10, you will a stop cable that anchors on figure 31, item 7. The end of the cable then hooks to item 2 on the stop devise. You have got items 7 and 2 showing in you last picture. The stop cable is not shown on the US sold, that is why I wonder where you are located. Make sure item 31 is all the way forward. Referencing all this in the 169 parts manual. Here is a picture of my old 2002D with the same setup.
Thank you! I am located in Manitoba, Canada.
Is there a Karma/Reward system?
This looks like it would work exactly like the shutoff cable on my Case 1070.
Pull it and it shuts off the fuel. So if that lever is moving on it's own. It is just randomly restricting fuel.
Which _could_ explain most of my problems!!!!!
/ Missing spring? Yanmar 169D #9
Sounds like injector pump
/ Missing spring? Yanmar 169D #10
I think Winston is right, that lever is for a stop cable. A feature that may not have been on your Yanmar.
I have two Yanmars from the same era, plus once had another, and all look like yours - an unused empty bracket and lever. I always wondered what that was for.
As for your problems - I had the same issue. Stall under load, then easy restart.
Solved by blowing out the fuel lines and replacing the fuel with fresh. Last week, a year later, I finally got around to filtering that old bad fuel hoping to re-use it. Some of it was in a white jug. I saw a lot of sediment had settled, maybe a tablespoon in a gallon. Another larger fuel jug poured out clean until the last pint which had sediment plus strings of black 'cotton'.
And I discovered a paper coffee filter will soon load up with the oils in Diesel and quit filtering. I then used two, stacked, permanent (brass? mesh) drip-coffee filters. Maybe more ideal would be to put temporary tubes on the tractor's fuel filter assembly for finer filtering.
In summary - drain your fuel near empty. blow compressed air from the filter fitting back to the tank and suck out the bottom of the fuel tank, then blow out the fuel line from the pump connection back to the filter assembly. Replace filter and fuel with fresh. Months later filter the old fuel into transparent containers to see what has settled out. If you're cheap like me, re-use it after filtering.
Added - draining to a jug from the line down to the pump, would take advantage of the tractor's filter. Then suction out the final 10 percent from the tank and discard that.
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
Case 590 SUPER M SERIES 2 (A65053)
Case 590 SUPER M...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
