Snowblower Missing driveshaft in snowblower
/ Missing driveshaft in snowblower #1
Jim_W
1952 Ferguson TEA20, 1951 Ferguson TEA20
I'm looking at an old snowblower that is missing its pto driveshaft. It would need to have the female part to fit onto the pto, a U-joint, a sliding inner shaft inside an outer shaft, another U-joint, and I guess something with a shear pin.
My question is - are these things standardized, or will I have to make something up? (hope not).
Thanks,
Jim
/ Missing driveshaft in snowblower #2
Any farm supply store or farm equipment dealer should have everything you need. The connection at the snowblower is the one you'll have to identify. With that and the length between tractor and blower, you should be set. Most places have complete pto shafts including the guards.
Thanks; that's reassuring.
Another question - I have come back to having a tractor and implements after many years away from them. Now I see there are plastic guards on the driveshafts but are they there in case the U-joint comes apart, or what? I can't quite see their advantage - unless it's just that they're smooth so things don't get snagged on them as easily.
Jim
/ Missing driveshaft in snowblower #4
The plastic guard is supposed to be chained so that it does not rotate. That way if something brushes up against the guard there is much less risk of wrapping around the shaft.
/ Missing driveshaft in snowblower #5
Plastic guards? Just a safety device (and a good one) to keep you from accidentally getting clothing caught on the PTO shaft when it's turning and getting yourself, or parts of yourself, wrapped around it.
/ Missing driveshaft in snowblower #6
Jim,
It has been my experiance that it can be more expensive to repair an existing PTO shaft than to replace it. Agri supply <A target="_blank" HREF=http://www.agri-supply.com/>http://www.agri-supply.com/</A> sells Eurocardian Italian shafts pretty reasonably. The Surplus Center has some PTO shafts too (1-800-488-3407). They also have a nice catalog.
Chris
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
10' Dozer Blade (A64119)
10' Dozer Blade...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
