Minimum tractor for loader
/ Minimum tractor for loader #1
Anonymous Poster
Epic Contributor
I would like thoughts on the minimum size and power needed w/4wd on a tractor to be able us a loader. Any recommendations on models of tractors.
/ Minimum tractor for loader #2
Well, that all depends on what you want to do with the loader. JD sells a little GT that has a loader, but it's use is highly debatable. The smallest that Kubota sells is the BX series, both 18 and 22 HP, and the tractor is large enough that the loader is very useful and fairly beefy, it has a capacity of around 465 pounds. I own the BX-2200 and have found it to be very useful and meets my needs. However, it could be a different story if you need to move 800 pound boulders, etc....
/ Minimum tractor for loader #3
I have a BX1800 w/Fel. After about 10 hours of using the combination it is every bit as productive as I expected. Of course it has it's limitations, but from what I've seen, heard, and experienced, I would consider it a very good entry level Tractor and Loader, all depends upon your expectations.
/ Minimum tractor for loader #4
CRAIG: u really need to be a little more specific in what u want to do with the tractor.i have seen fel's on garden tractors . they won't do much but they are available.
Frank
2021 ISUZU NPR CAB AND CHASSIS (A63569)
2021 ISUZU NPR CAB...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CHEVROLET C-60 GRAIN TRUCK (A63291)
CHEVROLET C-60...
