Minimum tractor for loader
/ Minimum tractor for loader #1
Anonymous Poster
Epic Contributor
I would like thoughts on the minimum size and power needed w/4wd on a tractor to be able us a loader. Any recommendations on models of tractors.
/ Minimum tractor for loader #2
Well, that all depends on what you want to do with the loader. JD sells a little GT that has a loader, but it's use is highly debatable. The smallest that Kubota sells is the BX series, both 18 and 22 HP, and the tractor is large enough that the loader is very useful and fairly beefy, it has a capacity of around 465 pounds. I own the BX-2200 and have found it to be very useful and meets my needs. However, it could be a different story if you need to move 800 pound boulders, etc....
/ Minimum tractor for loader #3
I have a BX1800 w/Fel. After about 10 hours of using the combination it is every bit as productive as I expected. Of course it has it's limitations, but from what I've seen, heard, and experienced, I would consider it a very good entry level Tractor and Loader, all depends upon your expectations.
/ Minimum tractor for loader #4
CRAIG: u really need to be a little more specific in what u want to do with the tractor.i have seen fel's on garden tractors . they won't do much but they are available.
Frank
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63118)
Magnolia Trailer...
2016 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 VOLVO VNL630...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
