Minimum tractor for loader
/ Minimum tractor for loader #1
Anonymous Poster
Epic Contributor
I would like thoughts on the minimum size and power needed w/4wd on a tractor to be able us a loader. Any recommendations on models of tractors.
/ Minimum tractor for loader #2
Well, that all depends on what you want to do with the loader. JD sells a little GT that has a loader, but it's use is highly debatable. The smallest that Kubota sells is the BX series, both 18 and 22 HP, and the tractor is large enough that the loader is very useful and fairly beefy, it has a capacity of around 465 pounds. I own the BX-2200 and have found it to be very useful and meets my needs. However, it could be a different story if you need to move 800 pound boulders, etc....
/ Minimum tractor for loader #3
I have a BX1800 w/Fel. After about 10 hours of using the combination it is every bit as productive as I expected. Of course it has it's limitations, but from what I've seen, heard, and experienced, I would consider it a very good entry level Tractor and Loader, all depends upon your expectations.
/ Minimum tractor for loader #4
CRAIG: u really need to be a little more specific in what u want to do with the tractor.i have seen fel's on garden tractors . they won't do much but they are available.
Frank
5ft Tiller (A64047)
5ft Tiller (A64047)
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
