Milwaukee 18V impact gun?
   / Milwaukee 18V impact gun? #81
I have several Milwaukee 28 volt tools. Don't understand why "M" discontinued them. They are great tools. When you pull the trigger, they work. The 1/2" impact is heavy and bulky but it gets the job done. If it doesn't get the bolt lose, I have to go to the 3/4 sockets and 36" break over. If that don't work, the heat wrench.
I agree. the M 1/2" Fuel is heavy. but it does the job my Ryobi 1/2 18vt won't. I only use it when my ryobi sticks it's finger out at me. like the 5/8" Shank bolts with 15/16 heads that hold the blades on to my woods 60" deck and their left handed
   / Milwaukee 18V impact gun? #82
I'm the OP and that's my original post in wanting to buy a 1/2" drive 18V impact gun for basic farm, auto and tractor work.
After all the very helpful comments and because I had Makita things already, I wound up with the 3/8" Makita 18V and it's perfect for me. I mail ordered from Home Depot after Amazon sent me an open box return I didn't want.
It's lightweight, shockingly powerful and easy on the battery. Just for chuckles I tried on my 150 ft lb Tundra wheels and it zipped them off. no problem. It has multiple power settings so I use the lightest when putting nuts back on and now I can easily hold the difficult "hubcap" in place while installing.
1/2" impact would have been too much for my use. Sure, for tough stuff I would need it and if I still had big equipment it would be a universal tool for all of that and everything else. For that I have a 1000 ft lb air gun so that's my backup. FYI
This is my most used impact outside of the 1/4' impact driver.. The thing is real smooth and a beast for its size.
   / Milwaukee 18V impact gun? #83
I have a 1/2" Baurer that I carry around in my van with 8lug wheels. I was in HF one day and there was a 3/8" open box tool only that looked like it had never been used so I picked it up. I am impressed when I use that 3/8" and what it will do. I usually only get the 1/2" out when I think it's time to charge the battery.
FWIW when it comes to online, my last couple of non tool ebay purchases have me questioning? Poor seller communication, items full filled by Amazon and/or Walmart, and my name incorrect on the label when the items came.
   / Milwaukee 18V impact gun? #84
Do you have a magnetic socket for the 1/4" hex bits yet?
I've been using the sockets since the 9 volt Snapon 3/8" impact was the thing to have. I like the square drive with the magnetic socket, way better than the cordless impacts with the 1/4" chucks
   / Milwaukee 18V impact gun? #85
those are good. I have a metric & sae 1/4 dr set I bought 25 yrs ago before I retired as a auto tech. these are the sunnex and work really well & warranted for life, never broke one. they were $68 back then, I have no idea now. I also have the makita 12vt drill & flashlite kit from 20 yrs ago, & ryobi 18vt flashlite,drill & 1/2 impact I still use a lot. I only break out the heavy Milwaukee 18vt impact when the job is too hard for the Ryobi
Yes, I have a magnetic socket but is not impact rated or anything like that.
I do have a 3'8" to 1/2" drive adapter on most of the time because 1/2" are the sockets I use the most.
I'm the OP on this thread and let me thank everyone for helping and convincing me to buy a 3/8" battery impact gun for farm and shop use. As mentioned, I went with Makita because I already had batteries and chargers but I suspect most brands are as powerful. I see a lot of Milwaukee and DeWalt around.
Anyway, I can't believe the power and usefulness of this little 3/8" impact gun. It loosens F250 lug nuts, no problem. Implement bolts and things it shouldn't loosen, it easily loosens. Everything--so far. It's hard to believe the small size and power within. It will have limitations but for me, none yet. When I do, I'll add a 1/2" version.
Bottom line, these newer 3/8" battery powered impact guns are worth it for many uses around a home or farm. FYI.
   / Milwaukee 18V impact gun? #88
I agree that the 3/8"is the new 1/2" I have a Milwaukee M18 1/2" impact wrench. I just purchased a Milwaukee M18 3/8" impact wrench. Much lighter and more nimble. 600 ft lbs of of torque is more than enough for 99.9% of my needs. Plus it has 4 torque settings, including a soft stop (35 ft lbs) for tightening.
I think you made a good choice.
   / Milwaukee 18V impact gun? #89
The link you have is the tool only currently, but here is the link for two XC6.0 5.0Ah batteries and charger
I've been buying Tools at Home Depot and Lowes lately. I get better quality, they have everything, it's priced honest, I can return it no questions and they'll bring it to my door, generally for free. And I spend zero on gas.
No more big-box Internet places selling open box, used and returned tools.
   / Milwaukee 18V impact gun? #91
Next on your list is the 1/4" nut driver
I Have all three impacts from dewalt. 1/2", 3/8, and the 1/4" nut driver. Plus a Mikita 40vlt 3/4" impact.
I use the 1/4" the most. I picked up a master set of bits for it which also came with the 1/4 socket adapter.
I'm constantly removing screw clamps, sheet metal screws, small nuts and bolts on equipment at work.
I then bring it home to use for carpentry projects.
My 3/8 is used for medium sized bolts, and then the 1/2 comes out for large bolts.
The 3/4" gun is dedicated to extra large bolts, it's darn heavy, and I avoid using it unless I need too
   / Milwaukee 18V impact gun? #92
My Thor 1/2" drive air impact will run circles around the Milwaukee or the Dewalt (1500 pounds feet breakaway torque) plus it's lighter and costs less. Downside is you need sufficient compressed air to operate it, which I have. My Thor routinely snaps off A325 dome head plow bolts used to secure cutting edges on dirt and snow plows that are severely corroded. Not into heavy duty Li-Ion powered tools and never will be. Prices is too high to begin with and with air power, so long as my compressors and compressing, they don't ever slow down or loose their poop. If the Thor won't bust 'em, my 1" drive IR will... 2500 pounds feet breakaway.
   / Milwaukee 18V impact gun? #93
If you say so.
My Dewalt cordless 1/2" has 1400 FT pounds breakaway torque, and I can take it with me wherever I want and use it.
I have plenty of air tools. Fine for in the garage.
Don't do me any good if I'm not near an air compressor.
I have a Dewalt 1/4" cordless Impact.
A Milwaukee 3/8" and Dewalt 1/2" cordless impact. Handy as hell, use them all the time.
   / Milwaukee 18V impact gun? #94
My snap on 1/2" pneumatic impact will run circles around my 20vlt dewalt impact.
My pneumatic impact very rarely gets used anymore though.
It's rather nice being untethered
   / Milwaukee 18V impact gun? #95
Whatever. Keep in mind that the Milwaukee and DeWalt tools are all built in the same Chinese factory, actually the same factory that makes HF cordless tools.
My preference is avoid buying Chinese as much as possible actually.
I don't consider an air supply hose a 'tether' at all.
   / Milwaukee 18V impact gun? #96
If you say so.
Until the battery looses it's poop and then they are all rocks.
   / Milwaukee 18V impact gun? #98
That is why I have multiple spare batteries
All my cordless tools are Dewalt and Milwaukee, I have multiple spare batteries for each.
   / Milwaukee 18V impact gun? #99
I'm on 8 years of heavy use on my dewalt impacts. And that 1/2" gun has seen serious usage daily. Half of that was inclement weather.
I'm quite pleased with it. Before the dewalt, I burned through a Milwaukee in two years, and a Hilti in 1 1/2 years.
   / Milwaukee 18V impact gun? #100
No, they are not. TTI owns Milwaukee, and they make Walmart's Hart, not Harbor Freight. They also make Ridgid and Ryobi power tools sold at Home Depot.
Stanley Black & Decker owns DeWalt, and they also make Craftsman and Black & Decker tools.
Milwaukee makes tools in Malaysia, China and the USA.
DeWalt makes tools in China, Mexico, Brazil, and the USA
Who makes HF's power tools has not been publicly disclosed..
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
John Deere 1025R (A53317)
John Deere 1025R...
CAT 930M (A58214)
CAT 930M (A58214)
