Dftodd
Super Star Member
- Joined
- Oct 19, 2014
- Messages
- 10,501
- Location
- vilonia, arkansas
- Tractor
- Massey Ferguson 1825E, Kubota Z121S
Next on your list is the 1/4" nut driverI'm the OP on this thread and let me thank everyone for helping and convincing me to buy a 3/8" battery impact gun for farm and shop use. As mentioned, I went with Makita because I already had batteries and chargers but I suspect most brands are as powerful. I see a lot of Milwaukee and DeWalt around.
Anyway, I can't believe the power and usefulness of this little 3/8" impact gun. It loosens F250 lug nuts, no problem. Implement bolts and things it shouldn't loosen, it easily loosens. Everything--so far. It's hard to believe the small size and power within. It will have limitations but for me, none yet. When I do, I'll add a 1/2" version.
Bottom line, these newer 3/8" battery powered impact guns are worth it for many uses around a home or farm. FYI.
I Have all three impacts from dewalt. 1/2", 3/8, and the 1/4" nut driver. Plus a Mikita 40vlt 3/4" impact.
I use the 1/4" the most. I picked up a master set of bits for it which also came with the 1/4 socket adapter.
I'm constantly removing screw clamps, sheet metal screws, small nuts and bolts on equipment at work.
I then bring it home to use for carpentry projects.
My 3/8 is used for medium sized bolts, and then the 1/2 comes out for large bolts.
The 3/4" gun is dedicated to extra large bolts, it's darn heavy, and I avoid using it unless I need too
