Mig welding question
/ Mig welding question
My first post is misleading there. Those are the widths. Both bars are 1/8" thick so not a problem even for this welder.
/ Mig welding question #15
I would unplug it and remove the metal covers. Be careful but I would use an air compressor to blow any dust inside it out to clean it up the best you can. Then look for something that might be damaged. It's possible that the duty cycle didn't kick in quick enough to prevent something overheating.
I blew it out yesterday and it seemed to help for a while but then started acting up again. Not sure if the wire stops feeding in fact I think it still does. Its like as it gets warmed up it acts up. Will inspect closer though.
/ Mig welding question #17
If you're getting erratic wire feed or stuttering, it could be that the tip or wire extension has heated up and there is a clearance problem. I had to run the next size up tip to prevent grabbing on a Tweco gun when I was dumping the amps into a big gate with lots of continuous welding.
Since this seems to be showing up when things are hot enough to kick the thermal, it's worth a look. Even a small berry stuck to the tip can cause binding.
/ Mig welding question #19
When it acts up does the wire still come out? Or does it stop? Make sure the wire isn't melting causing you to loose the arc. If you have the power turned up too high for the speed at which the wire is fed the wire will melt back up to the tip and loose the arc. Maybe try welding while having someone watch the spool to see if it stops turning or isn't turning smoothly while it's acting up.
/ Mig welding question #20
Maybe it has heat sensitive failure ..Can you put volt meter across the contact tip to ground and see a voltage reading when it fails... should read about 18 to 25 volts DC continuous with trigger pulled....
Dale
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
KJ K2010 20'Lx10'Wx8'H Chicken Coop (A60463)
KJ K2010...
