Mig flowmeter suggestions?
/ Mig flowmeter suggestions? #11
A word to the wise: Don't leave your tank turned on when not in use.:)
/ Mig flowmeter suggestions? #12
Really? I just upgraded to a larger (60gal) tank compressor. I have been leaving it auto/on 24/7. It's a lot of air to drain. Are you suggesting to just turn it off or depressurize as well? Takes me 7 minutes to fill from zero... and a fair amount of time to purposely empty.
/ Mig flowmeter suggestions? #13
I am referring to your high pressure argon or CO2 tank as used for welding. I don't trust solenoids and regulator diaphragms not to leak.:)
/ Mig flowmeter suggestions? #14
Aha! Yes, agreed. I have air compressor on my mind as I have been plumbing my shop, trying to reduce moisture in the supply, etc. I should start a thread on my ordeal with my new HD compressor.
/ Mig flowmeter suggestions? #15
I have a ball valve 1st in line on my compressor. I always forget to turn it off when done. It takes a while but I can hear the compressor in my shop kicking on from the house in summer months. If this was my mig or tig tank, I'd be broke by now.
/ Mig flowmeter suggestions? #16
So do I... I guess I should turn that off nightly because I do have a very slow leak downstream. Well I think it is downstream in the quick connections but actually haven't tried to isolate it yet. So much better than my old 20gal compressor that leaked such that it was cycling so much it was very annoying.
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
1008 (A61166)
1008 (A61166)
2018 FORD F-350 FLATBED (A60736)
2018 FORD F-350...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
