Mig flowmeter suggestions?
/ Mig flowmeter suggestions? #11
A word to the wise: Don't leave your tank turned on when not in use.:)
/ Mig flowmeter suggestions? #12
Really? I just upgraded to a larger (60gal) tank compressor. I have been leaving it auto/on 24/7. It's a lot of air to drain. Are you suggesting to just turn it off or depressurize as well? Takes me 7 minutes to fill from zero... and a fair amount of time to purposely empty.
/ Mig flowmeter suggestions? #13
I am referring to your high pressure argon or CO2 tank as used for welding. I don't trust solenoids and regulator diaphragms not to leak.:)
/ Mig flowmeter suggestions? #14
Aha! Yes, agreed. I have air compressor on my mind as I have been plumbing my shop, trying to reduce moisture in the supply, etc. I should start a thread on my ordeal with my new HD compressor.
/ Mig flowmeter suggestions? #15
I have a ball valve 1st in line on my compressor. I always forget to turn it off when done. It takes a while but I can hear the compressor in my shop kicking on from the house in summer months. If this was my mig or tig tank, I'd be broke by now.
/ Mig flowmeter suggestions? #16
So do I... I guess I should turn that off nightly because I do have a very slow leak downstream. Well I think it is downstream in the quick connections but actually haven't tried to isolate it yet. So much better than my old 20gal compressor that leaked such that it was cycling so much it was very annoying.
2015 Honda Accord Sedan (A59231)
2015 Honda Accord...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2018 FREIGHTLINER...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2023 FORD F-150 (A60736)
2023 FORD F-150...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
