Middlebusters - am I missing something?
/ Middlebusters - am I missing something? #21
just an FYI when working ground and turning sharply. always raise tillage tool just to coverr tractor tracks. it is a lot easier on the tillage tool and tractor .
/ Middlebusters - am I missing something? #22
Good point, must have fallen asleep last year, broke a couple of disc blades, they are old and brittle. I TIGed them back together so far so good.
/ Middlebusters - am I missing something? #23
Eastinlet said:
neil -
Couple of things to consider when hilling.
First is when to hill, and that is best done at 8-12" in plant height. The buried stem will sprout tubers, and all tubers form between the buried seedpiece and the surface of the ground. If you let the plants get away from you like I did last year, it is a royal pain to hill in a tangle of vines.
Height of the hill is basically as broad and high as you can make it. On 36" row centers you will be grabbing dirt almost to the center of the row middle. With 10" plants you want them covered right to the tips if you can do it. Don't worry, they'll grow back out from under the dirt.
Hilling twice say 2 weeks apart works well if you have the time or spit for it. If you do this, you can hill first when they are say 6" and then hill again at 12" or so.
If you look at the linked photo I posted above you can see hills down the rows of dead vines. It was a poor job on my part and of course the hills settle over the summer so they aren't as dramatic as they are fresh.
The trick is to mechanize the hilling using disks or cultivators rather than a hoe. the big farmers up this way use Lilliston rolling cultivators which throw the dirt from row centers onto the hill and can do many rows at once. The old horsedrawn hillers used cultivator teeth to loosen ground for two opposing angled disks which scooped dirt to the hill. I'm working toward mechanizing, that hoeing just isn't as fun as it used to be.
I use a furrower that looks like a middlebuster behind my Troybuilt walk behind tiller to make the rows for my potatoes. I fertilize, then pull in a bit of dirt, and set the seed. I hill mine when they are up 6-8" or a bit more. I run the tiller between the rows to make the soil as loose as possible, and then pull it up on the plants from both sides as high as possible. Last year I used more compost than commercial fertilizer, but I still had a pretty good crop. I am just using up the last of them now. Have to plant a few more this year, and get a tractor involved in the action!
How do you guys control the depth of the middlebuster. I could control the depth of the one I tried on my BX with the top link to some extent, but it would just be my luck that the tip would run right through my mature potatoes! :D :D
/ Middlebusters - am I missing something? #24
Chuck -
I control the pitch of the plow with the toplink so I get maximum lifting action. Could actually use a longer toplink in my case.
i control depth via the 3 point position control and have room to go deeper should I wish to. I try to get just below the seedpieces, or in other words about the depth of the original planting furrow.
Definitely does a nicer job with moist soil as opposed to wet, and works a lot better with dead vines than live ones. Less clogging and tangled mess.
/ Middlebusters - am I missing something? #25
Thanks for the response Eastinlet. It would take a little room to get the middlebuster down to depth before encountering the potatoes. I didn't have position control, and kind of fudged that by letting it go to depth, and "bumping" it up the same number of times each pass. I sure would like to try that! I don't mind hilling potatoes, but I'm starting to find digging them by hand a little tiring if I don't have much time.
/ Middlebusters - am I missing something? #26
East and all others,
Thanks for the help I think I gety it now, just got to try it.
Best, Neil
Wow I've learned a lot to. I'll have to feed mine more. The water is the only wildcard. I plant early sometimes because we get more rain. But the spuds are the only thing that survive the lack or water.
I also don't get all the vines yall mention. hmmm. Here is a pic from last year...a good rain year. The stuff was planted 3/11/2007, the picture was taken on 4/7/2007. The spuds are the near 2 rows. So I'm guessing it looks like hilling time?
The rest is corn, then peas. The very small corn in the upper part of row 3 and 4 was planted on 3/26/2007.
1st pic is 4/7 , second pic is the 3/26.
/ Middlebusters - am I missing something? #28
RobJ -
Your potatoes look ok for 5 weeks, and that would be a great time to hill. They look a little light, maybe lack of N.
I have attached the only digital photo I have of plants/hills at about 7-8 weeks. The weedy rows in the foreground are the Red Norlands you have seen harvested. They are not hilled due to my busy schedule and carelessness, and they are weedy. In the upper left you can see clean and hilled rows of Superiors.
The vines are beginning to get into the row middles and will eventually completely cover them. The Norlands are worse in this regard than Superiors, which are more erect in form. Potato cultivars vary a lot in terms of growth habit and other physical features.
It really does pay to consider nutrient levels. I rely on soil analysis and recommend you have yours tested. A crude rule of thumb would be to give taters 30-50% more than you would corn, and they need quite a lot of phosphorous. My soils are very different than yours, but I am putting down 1500 pounds of 10-20-20 per acre.
You might try it as I do, i.e. trench-fertilizer-cover-plant seed-cover-hill. Not much to do about rain except plant early. Can you run soaker hose or irrigate? If you expect dry weather, you could space your seed further apart to reduce competition. That will help.
Potatoes are tough as nails, they can even grow just sitting on the ground. Problem is they won't make many tubers unless they have what they need. They are a cool season plant whose optimimum temperature is 70 degrees. The hills help control heat on the roots. They need an inch a week of rain as an ideal when the tubers are bulking. Tubers are mostly water, so you can see the need.
I don't know what you have for insects and disease, but they are a problem wherever potatoes are grown. Attached photios are of Colorado potato beetle adult and larvae which will reduce yield to the level of a joke in a short time by defoliating the plant. I have trouble with leafhoppers some years, for their tiny size they sure hurt the crop. I have to spray against early and late blight as well, the latter being what caused the Irish potato famine. It will ruin you.
This thread may die out eventually, so you guys with questions can PM me any time if I can help you any. Don't know how much I can help, but always willing to try.
Hmmm, maybe our potatoes are different, just what we call red potatoes around here. But I've never seen a vine one on the ground like that. Water gets what the Lord provides. I tried to pump from a pond one year when we got no rain. Didn't do much. I have limed the place since it's real sandy. It use to be part of a wild pasture. Here is a pic of the first year. I think i turned over and replanted 50,000,000 goat weeds. :D It's getting better as I disk it about 4 times a year. I don't have the time to work it since its at the weekend place. Mainly just something to play with.
/ Middlebusters - am I missing something? #31
How do you "keep" that many potatoes? Do you leave them in the ground until you need them?:rolleyes:
Thanks
/ Middlebusters - am I missing something? #32
/ Middlebusters - am I missing something? #33
Bill Barrett said:
Nice link, how the heck do horses pull the finish mower and tiller? :D
I didn't follow the link, but I would think that the PTO hookup would be more of a problem than the pulling part. :D :D :D
/ Middlebusters - am I missing something? #34
Thanks
Nope, just dig them up and sack them and move them out of the field. I then disk and plant rye to protect the ground and grab any excess nitrogen.
The big growers move their stuff to market as fast as they can and put the remainder into atmospherically controlled storage.
The produce we grow is for the community, we feed the needy and elderly. We get sacks of potatoes to our customers who can use large quantities, i.e. families, at harvest time, eliminating the need to store. Then we have a fairly efficient method of distributed storage whereby the sacks go to volunteers who have either cold or warm cellars. The warm cellar potatoes get bagged into smaller bags and are taken around by volunteers with the objective of using them up by Christmas. The cold cellars can keep the remainder in good condition for distribution through spring.
/ Middlebusters - am I missing something? #35
That's a good plan. I am going to look into doing that this year since I can't use much of my produce alone. I've also thought about seeing if there were any of those folks who would like to garden, and let them use some of my space. Not sure how to go about that though. I admire your efforts, and thoughts.
/ Middlebusters - am I missing something? #36
Chuck -
Anyone interested can PM me if they would like to know more about community gardening. I'd be happy to share our experience with anyone caring about their community. There are a number of ways to go about this, and it pays to consider alternatives before beginning a project.
There are ways to pool resources and labor to make large gardens possible.
Don't want to stray too far off topic in this thread.
/ Middlebusters - am I missing something? #37
As for irrigating potatoes, I have my gardens on drip. I have dug a nice deep trench (hiller behind the tiller), lay in the drip hose (had about 12" spacing on the emitters) cover that with about 3 inches of soil. Run the water a bit and drop the seed potatoes on the wet spots and cover. I hilled as normal and come harvest time was able to yank the drip hose up out of the ground and then hand dug the potatoes. The drip runs daily and I was afraid of too much moisture. Our soil does drain well though and at harvest I did not have any rotten potatoes.
/ Middlebusters - am I missing something? #38
Are you running drip or microdrip, such as T-tape?
I've been thinking about trying micro for the field, maybe every other row the first year and compare yield to see if it pays.
The stuff is actually pretty cheap, I think around $200-250 for 10,000 feet of 6 mil. The 6 mil is basically throwaway stuff, and that's fine since my digger will damage it. Doesn't take much flow or pressure to irrigate either, it won't handle more than about 15 PSI. I called trickle-eez, one of the major suppliers and spoke with a capable guy who was able to answer my questions. I'm thinking hard about trying it for mid-summer when it gets so dry.
/ Middlebusters - am I missing something? #39
I just use the 5/8 poly and put emitters in it. I tried the stuff with emitters already in it but didn't really care for it. This was I can easily change out emitters if they clog and build my own lines with whatever spacing I want.
Excavator Grapple (A64127)
Excavator Grapple...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
We do NOT accept credit cards as payment. (A64126)
We do NOT accept...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
3pt Tractor Weight Set (A64127)
3pt Tractor Weight...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
